Beast with a Thousand JFETs
Old 13th May 2013, 08:15 AM   #291
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
for each pair
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 13th May 2013, 09:14 AM   #292
Luda is offline Luda  Germany
OK, will try that once I get a new soldering station, thanks.
I guess the current circuit is oscillating, with charge flowing from one gate to the other, but I haven't hooked it up to my old scope yet...
Old 13th May 2013, 09:16 AM   #293
Zen Mod's Avatar
if that is more convenient , layout wise , you can have gate resistor for each jfet
Old 13th May 2013, 08:58 PM   #294
pidesd is offline pidesd  Canada
pidesd's Avatar
luda,
also,
look to have a resistor from input to ground
Old 13th May 2013, 09:15 PM   #295
Zen Mod's Avatar
one input resistor , common for all parallel cells , is exactly enough
Old 13th May 2013, 10:14 PM   #296
Loudthud is offline Loudthud  United States
Loudthud's Avatar
I would suspect a simple difference in Vgs (and Yfs) is causing your offset. Matching Idss between P and N channels doesn't address this issue.
Old 13th May 2013, 11:39 PM   #297
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I build the circuit shown above and get anything between 0.2 and 1 Volt Vout.
Due to the untimely death of my soldering station I'm not that motivated to go bug-hunting right now, but should I have used a 1k resistor for every pair of 2SK170/2SJ74 or even 1 for every FET?
Scott Wurcer has commented authoritatively (IMHO) that a single resistor will
stabilize 4 of the 2SK170 / 2SJ74. In other words, 2 pair. I think you are probably OK.
How closely did you match Idss of the parts?
Old 18th May 2013, 11:38 AM   #298
Antoinel is offline Antoinel  United States
Strange; this thread no longer has my past contribution posts.
Beast with a Thousand JFETsHide this!Advertise here!
The beast OTL daly41k Tubes / Valves 0 18th January 2009 03:09 PM
Thought experiment: A thousand 12V car batteries in series bigwill Everything Else 6 21st June 2007 03:56 AM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
Making a beast of an amp sbattersby 115 Instruments and Amps 29 16th May 2005 03:28 PM
Hello from the land of thousand smiles, Thailand fahlap Introductions 2 26th December 2004 05:32 AM
