Beast with a Thousand JFETs
Old 13th March 2010, 09:20 AM   #191
EUVL is offline EUVL  Europe
You divide peak VOLTAGE by root 2 to get Vrms. But it is also the same for current in resistive load. So power is divided by 2.
Or am I still wrong ?
Patrick
Old 13th March 2010, 11:21 AM   #192
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Audio power - Wikipedia, the free encyclopedia
Old 13th March 2010, 02:47 PM   #193
juma is offline juma  Germany
juma's Avatar
Patrick
Sorry Patrick, I don't know why I asked at all - absolutely unimportant because this calculation assumes pure resistive load and sinusoidal signal - pretty much useless in real life.
Peak voltage/current value might be informative - it determines the clipping limit, the rest is of no use, unless we want to go into really complex modeling...
Old 13th March 2010, 03:02 PM   #194
> Peak voltage/current value might be informative ....
That we agree.
And in post #189 I was working back from what Nelson quoted in post #186 back into, exactly as you said, voltage, current, and thermal dissipation.
Patrick
Old 13th March 2010, 04:35 PM   #195
Blues is offline Blues  United States
Blues's Avatar
Patrick
This is correct. The square of the square root of 2 is equal to 2...
Prms=(Vrms)^2/R
since Vrms=Vpk/sqrt 2 then:
Prms=(Vpk/sqrt 2)^2/R; this then equates to:
Prms=(Vpk^2/2)/R)=Vpk^2/(2*R) or the customary =(Vpk^2/R)/2
As an example with the known values Vpk=20V and R=8
Prms=(20^2/8)/2=25 watts
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 13th March 2010, 05:08 PM   #196
It was not supposed to be a question.
Patrick
Old 7th October 2010, 05:29 PM   #197
gl is offline gl  United States
Hi Nelson,
I was wondering how this project was coming along. Have you had a chance to do any preliminary or even serious listening and if so can you share your thoughts on the sound?
Thank you.
Graeme
Old 8th October 2010, 12:47 AM   #198
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
At this time I have 5 pc boards completely stuffed, ready
for action. Four of them perform as previously described,
and one of them has a little extra distortion.
I began searching for the bad device by measuring the THD
at the Source pin of each of the 588 devices on the board,
and I got half way through before I had to go work on other
things for a while.
In actual testing the best performance looks to be with
supplies in the +/-15V area - battery operation is very
feasible. To get the power up I can run two pc boards
in balanced mode, and this looks like what I may do,
creating one stereo pair at about 40 watts and a single
board suitable for two channels at 10 watts or less.
I may have it a BAF, then again I might have something
else.
Old 8th October 2010, 05:49 PM   #199
nar is offline nar
nar's Avatar
I think this project is awesomely insane
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 8th October 2010, 07:29 PM   #200
The one and only
It's become the Beast With 2,352 Jfets.
Beast with a Thousand JFETsHide this!Advertise here!
The beast OTL daly41k Tubes / Valves 0 18th January 2009 03:09 PM
Thought experiment: A thousand 12V car batteries in series bigwill Everything Else 6 21st June 2007 03:56 AM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
Making a beast of an amp sbattersby 115 Instruments and Amps 29 16th May 2005 03:28 PM
Hello from the land of thousand smiles, Thailand fahlap Introductions 2 26th December 2004 05:32 AM
