Beast with a Thousand JFETs
Old 12th March 2010, 04:04 AM   #181
EUVL is offline EUVL  Europe
May I ask what rail voltages (+/-15V) ?
Patrick
Old 12th March 2010, 06:42 PM   #182
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It's variable at this point. The absolute limit is about +/-20V.
Old 12th March 2010, 06:45 PM   #183
PMA is offline PMA  Europe
PMA's Avatar
Distributed low power ...
Old 12th March 2010, 07:09 PM   #184
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
I see it now. The Pass DLP amp ... patent pending!
My Website: Hyperacusis, Tinnitus, My Story
Old 12th March 2010, 09:53 PM   #185
Blues is offline Blues  United States
Blues's Avatar
@5mA/jfet we have 100W/ch push-pull Class A? No heatsink required
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 12th March 2010, 11:04 PM   #186
The one and only
It would dissipate 100 watts. Output power would
probably be about 20 watts.
Old 12th March 2010, 11:05 PM   #187
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Ghee butter, 588 JFETs per channel looks UFOddball enough.
588 at 6mA each is about 50W peak in 4.
Old 12th March 2010, 11:28 PM   #188
Blues's Avatar
still cool...
Old 13th March 2010, 03:41 AM   #189
20W is voltage limited at 8 ohm.
50W peak is 25W RMS. That would be something like 3.5A, 14V for 4 ohm. I max will be 12mA per JFET, which means V grade or some forward bias.
50W RMS at 4R requires 17mA per FET. You need to use V grade AND forward bias. And dissipation at the required 20V rail will be a bit high, so that the case temperature will be a touch higher than the reported 45°C.
30W rms at 6 R is 3A 18V. 180mW dissipation per FET.
Patrick
Old 13th March 2010, 09:01 AM   #190
juma is offline juma  Germany
juma's Avatar
Originally Posted by EUVL View Post
50W peak is 25W RMS. ....
Patrick, shouldn't that be: 50W peak is 25W average ?
My professors taught me that you get RMS value by dividing peak value with square root of 2 i.e 1.41. So 50W peak should be 35.46W RMS
Beast with a Thousand JFETsHide this!Advertise here!
The beast OTL daly41k Tubes / Valves 0 18th January 2009 03:09 PM
Thought experiment: A thousand 12V car batteries in series bigwill Everything Else 6 21st June 2007 03:56 AM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
Making a beast of an amp sbattersby 115 Instruments and Amps 29 16th May 2005 03:28 PM
Hello from the land of thousand smiles, Thailand fahlap Introductions 2 26th December 2004 05:32 AM
