Old 4th September 2009, 09:59 AM   #91
jan.didden's Avatar
Originally Posted by Nelson Pass View Post
I bet you would.
Does anyone have problems opening Nelson's graph from this post? On my PC it keeps saying "loading..." indefinitely.
jd
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 4th September 2009, 10:44 AM   #92
Does it read 0.0024% THD at 1W without any NFB?
Old 4th September 2009, 10:54 AM   #93
Cave Man
Spooky Electric's Avatar
Converted it to jpg.
MY NAME'S NOT RIC!
Old 4th September 2009, 11:34 AM   #94
Atilla is offline Atilla  Norway
Yes, I believe it does
Old 4th September 2009, 11:53 AM   #95
soekris is offline soekris  Denmark
What about using smt jfets, in sot23 ? Linear are supposed to launch their LSJ74 soon, you could mount them on a thin PCB that you glue directly on a big heatsink.... Any thermal problem solved.
I know that Nelson don't like stuff he can't see, but it much easier to have a machine mount 1000's of smt parts....
Old 4th September 2009, 12:25 PM   #96
If we assume that the 588 jfets is for one channel in push-pull setup and unbalanced mode, driving into 8ohm load, then at 1W RMS each jfet will be driving a +/- 0.85mA (1.7mA pp) of load.
And it will be at 8Vpp.
Comparing with THD measurement of B1 buffer, this thousand JFET amp's performance seems to be too good.
The only explaination that I can think of is that the symmetrical output stage help to significantly cancel of the distortion.
Or else there could be some intellegent design in it, which I can't wait to see more details.
Old 4th September 2009, 12:42 PM   #97
Distortion sounds not too far off, Borbeley's paper claims 0.0078% THD at 3V into 1Kohm with a single pair. 1W into 8 ohm is 2.8V, and 500 pairs into 8 ohm is like single pair into 4Kohm....
Søren
Old 4th September 2009, 01:16 PM   #98
There might be an X hidden in between 1000 Jfets?
Old 4th September 2009, 01:19 PM   #99
I'm not sure if the AP machine measures THD+N or not, but I'd imagine that most noise would be averaged out over so many pairs.
Old 4th September 2009, 01:25 PM   #100
jan.didden's Avatar
Works. Muchos gracias!
jd
The beast OTL daly41k Tubes / Valves 0 18th January 2009 03:09 PM
Thought experiment: A thousand 12V car batteries in series bigwill Everything Else 6 21st June 2007 03:56 AM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
Making a beast of an amp sbattersby 115 Instruments and Amps 29 16th May 2005 03:28 PM
Hello from the land of thousand smiles, Thailand fahlap Introductions 2 26th December 2004 05:32 AM
Copyright ©1999-2013 diyAudio
