Old 13th November 2003, 05:09 PM   #131
Netlist is offline Netlist  Belgium
Netlist's Avatar
Originally posted by Edwin Dorre
very very nice!
I noticed you used a kind of silvered wire for your second version of the Aleph-X instead of normal 2.5mm^2 . Notice any difference in sound?
Edwin
It is not silver wire, just plain ordinary stripped wire.
To me the amps play the same, and if there would be any difference it will be difficult to say if it's coming from the wires.
/Hugo
Old 24th December 2003, 08:54 AM   #132
Netlist's Avatar
Over the past few weeks I noticed strange behaviour from the toroids. You all know the buzz a toroid makes at start-up, drawing a lot of current for a few seconds.
This buzz comes up randomly now, when the amps are powered up. Maybe it has always been like that except I only start notice it a couple of weeks ago. Suddenly both transformers start to buzz, very equally for about 5 to 20 seconds, then the noise disappears and comes back few seconds or minutes later and so on. Doesn’t matter if they play or not. There's no vast timing for the effect, it can happen twice in a minute, or twice in 10 minutes, more or less. Both amps are hooked up on the same power line so I started measuring it. Voltage varies between 228-236V. Frequency is a stable 50Hz, +/- 0.01Hz. Positive and negative dutycycle point is 50.25 and 49.75. DC +/- 1mV. I also measured the current trough the amp but it sits there nice and stable at about 6A all the time.
The funny thing is that no difference can be measured in all these conditions when the Buzz comes up. I then connected one amp to another socket from another circuit. Same problem.
Any thoughts?
/Hugo
Old 24th December 2003, 09:55 AM   #133
macka's Avatar
Hugo,
I have had the same noises / effects using large toroidals.....
My understanding is the noise you hear is core attemtping to saturate, and this is due in part to the very high efficiency of toroidals where there are no losses.
This is not unusual for toroidals and for audio applications the design can be varied to minimise the effect by using larger the normal core size for the given VA rating, hence toroidals for audio are often more expensive.
Also, power factor problems on your immediate mains power grid can give rise to transformer noise
Ian
Old 24th December 2003, 10:40 AM   #134
Bensen is offline Bensen  Belgium
Bensen's Avatar
Hugo,
I've the same problem with my two 500VA toroid's from Amplimo in my Crescendo amp (1982). First a thought the cause was that I mounted the tow toroid's on each other.
I've read a thread on this forum a while ago where there was the same problem, this person had changed the normal rectifiers to fast recovery ones or something. Than his buzz no longer appears. I never tryed that.
Ciao
Ben
Old 24th December 2003, 10:59 AM   #135
Netlist's Avatar
I might have found the cause.
My neighbour has a big electric welding machine.
His workplace is located in a part of the factory were we live and taps from the same source.
I also noticed that when the transformers is buzzing, the dutycycle changes more from the ideal 50%. From 50.3 to 50.8 .
So if I would change the recifiers, could that solve (part) of the problem?
Nice amp you made there, Ben
/Hugo
Old 24th December 2003, 12:28 PM   #136
diyAudio Moderator Emeritus
roddyama's Avatar
/Hugo
Hi Hugo,
I was going to post that we all share the power lines with our neighbors. What they do in their homes and shops will have an affect on our listening. Maybe you might want to try some of those high dollar line cords?? ... or maybe not?
Rodd Yamashita
Old 24th December 2003, 01:00 PM   #137
Netlist's Avatar
Rodd
I'm open minded enough to let the guy in who sells powercords that would pretend to eliminate my problem. After all, it will not take more then 2 minutes to test if it works
I just had a look inside my neighbours machine. The trafo is about the size of two of my AlephX's He doesn't want to convert it into an amp he says...
/Hugo
Old 24th December 2003, 09:51 PM   #138
wuffwaff's Avatar
Hi Hugo,
my Aleph 5 (2 x 600VA) has the same problem. It can be very quiet, then suddenly it humms very loud and almost vibrates out of my rack.
Changing my ac power to balanced took care of the problem for a few weeks but now it has returned again
It is sometimes started by very small things like connecting my P-3A DA converter wich must have a very nasty power supply.
I will try some things like snubbers on the rectifiers iun the next few weeks (I also read the thread) but I´m not shure this´ll help.
I would like to find a sollution before I start the power supply of my X (I´ve got the trafos already).
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 24th December 2003, 10:05 PM   #139
The one and only
Nelson Pass's Avatar
There are three typical causes for intermittent mechanical hum
from the transformer.
1) Your circuit might intermittently draw very large amounts of
current. This is not very likely.
2) Your AC line might have some DC type noise on it, which
saturates the transformer. Lamp dimmers and other Variac
type controlled equipment are the usual culprit, and a filter
network is the usual answer.
3) Your secondary system might be drawing, on average, more
current from one rail than the other, in other words, different
+ to ground than - to ground. If the secondary windings are
mismatched and you are using only 1 rectifier bridge for the
two polarities, this can cause the same kind of saturation as
in (2). This is common when there is high DC offset at the
output through the speaker. Besides balancing out the draw,
you can also cure it by providing one rectifier bridge for each
rail polarity, assuming that you have dual secondaries and
not just a center-tapped secondary.
Old 24th December 2003, 10:16 PM   #140
wuffwaff's Avatar
1) your right
2) not possible with a balanced ac power
3) this was the cause for quite a bit of mechanical humm from my Ono where the plus draws more current than the minus side but it doesn´t work for my Aleph with two bridges per channel and quite low (30mV) DC offset
Any explanation for the bad influence of connecting a 9V AC transformer to the same 230V power line????
william
Aleph-X: High-Power Version Blitz Pass Labs 333 14th January 2010 09:46 AM
industrial music for industrial people Stan Gielewski Music 45 8th October 2008 04:34 PM
AlephX High Power version circuit needed space2000 Pass Labs 3 13th June 2008 12:50 AM
Page generated in 0.18225 seconds (57.92% PHP - 42.08% MySQL) with 11 queries
