Old 27th August 2009, 03:55 AM   #1
frags is offline frags  Canada
Default Another way to insulate transistors from heatsinks
After trying mica and aluminum oxide ceramic insulators which gave me temperature 8-10C higher than directly mounted transistors I tried an intermediate small heatsink between a transistor and large heatsink.
This intermediate heatsink has much larger area than a transistor and even with a crappy thermal interface can conduct enough amount of heat from transistors to big heatsink.
So, a transistor is directly attached to a small heatsink (60x60x8mm aluminum plate). To insulate small heatsink from a big one I used a frame cut from transparent film for laser printers. This film easily survives laser printer heater (180C) w/o be scratched/melted. The thickness of film is 4-5 mils (~0.1mm).
The 0.1mm gap between small and big heatsinks is filled with high quality non-conductive thermal compound. I used Arctic Cooling MX-2 which has good thermal conductivity (5-6 W/mK, mica has only 0.3-0.4 W/mK) and high
dielectric strength (10-15 kV/mm). The small heatsink has a mounting hole where transistor's hole is. Additionally I used a washer made from the same film which placed between small and big heatsink in place where the mounting bolt goes through. To avoid the bolt touching small heatsink the hole in it is twice bigger than mounting bolt and insulating hub is used (I made one using same printer film).
So, I've got transistor insulated from the heatsink with maximum possible thermal conductivity.
Old 27th August 2009, 04:08 AM   #2
Iain McNeill's Avatar
very elegant solution. A bit like a heat spreader. The thermal resistance is in the insulation so with a greater area to insulate you can get the resistance down.
great tip! Thanks for the write-up!
Old 27th August 2009, 07:39 AM   #3
juma is online now juma  Serbia
juma's Avatar
Originally Posted by frags View Post
After trying mica and aluminum oxide ceramic insulators which gave me temperature 8-10C higher than directly mounted transistors I tried an intermediate small heatsink between a transistor and large heatsink....
What's the temp. difference now (using the same comparison method) ?
Old 27th August 2009, 07:43 AM   #4
pjp is offline pjp  India
pjp's Avatar
I assume all your collectors are at the same potential ;p
But seriously, like juma asked, did it result in lower temps ?
Of course you could take this approach all the way, and insulate the whole heatsink ...
Old 27th August 2009, 08:06 AM   #5
juma's Avatar
The idea is nice and and simple - to thermally extend the transistor's case, but the contact area between new/bigger transistor's case and the main heatsink also becomes bigger.
That's why I wanted to know - is the temp. of the original transistor's case lower now than it was before (all other things being equal)?
Old 27th August 2009, 08:24 AM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Depends on the thermal resistance of that laser printer sheet, which is probably not optimized for low Rth. The idea is very good, and will work best if you use as insulation the same material as is used for the 'normal' insulation parts. The thermal insulation rubber (don't know the exact name) can be bought as sheets, so you can cut it to size. That would work best here.
jd
/Another new issue: Linear Audio Volume 3!
Old 27th August 2009, 09:29 AM   #7
juma's Avatar
Originally Posted by janneman View Post
Depends on the thermal resistance of that laser printer sheet....
jd
Off course, and if frags can confirm measured improvement with that laser printer foil, we can have even better results with Rth-specialized materials (kapton and mica can be found in ribbons/sheets and cut to custom size)
Old 27th August 2009, 09:59 AM   #8
keantoken's Avatar
This sounds good, but I imagine plastic like this might have a significant dielectric constant. Do you think this could be a problem with the amount of area, becoming a small capacitor relative to the device?
I wonder if we could try paper soaked with oil as an insulator here. Boiled linseed oil comes to mind here, which has a puncture voltage of around 300V per mil. If we soak printer paper in it, we have about 4 mils of thickness which gives 1.2kV tolerance. Perhaps instead of using the paper immediately after soaking we can wait until it dries and then see how well it works? Doable?
I don't know if there would be a temperature problem. But if we use the paper when it's still wet, the oil on the outside of the device will dry, possibly sealing in the oil between the device and heatsink, preventing it from drying.
Good idea, frags. I will put this in my bookmarks.
- keantoken
Old 27th August 2009, 10:57 AM   #9
SY's Avatar
Polyester (the material used for those overheads) has a lower dielectric constant than the metal oxides. And much lower thermal conductivity, alas. As thick as it is compared to, say, a mica insulator, the capacitance will be lower. Temperature measurements of the small and large heatsink will give you a more quantitative idea of the thermal resistances.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th August 2009, 01:51 PM   #10
About temperatures:
Initial conditions - 30W transistor dissipation, big heatsink is blown with 12cm fan to keep it as cool as possible.
When the transistor was mounted directly to big heatsink it showed ~43C оn its case (I'm using IR thermometer). With mica insulator the temperature was ~51-52C. With intermediate small heatsink it was ~43-44C.
In the past I red an article of one guy who measured temperature difference between transistor (TO-220 case 20W) bottom and heatsink with different insulators. Here it is:
1. No insulation - 1C
2. BeO ceramic (0.85mm) - 3C
3. AlO3 ceramic (1.0mm) - 8C
4. Mica (0.2mm) - 23C (this mica is too thick, the good one with 0.05-0.07mm will give same as AlO3 ceramic)
5. Silicon rubber - 30C
why insulate transistors???? dognut Parts 14 4th May 2009 02:37 AM
Garage sale (transistors, heatsinks, misc parts) maurycy Swap Meet 2 27th February 2009 05:10 PM
help choosing heatsinks for transistors riotubes Parts 2 27th August 2008 11:27 PM
Heatsinks,Transformers,Transistors,Amplifiers PassFan Swap Meet 1 10th December 2001 02:51 AM
FS; heatsinks, toroids, transistors, boards,... km Swap Meet 7 12th September 2001 11:21 PM
Page generated in 0.15859 seconds (65.08% PHP - 34.92% MySQL) with 11 queries
