Old 24th August 2009, 04:33 PM   #1
toufu is offline toufu  United States
Default Neatness of wires?
I finished a couple of Pass clone builds and I have wires running all over inside the chassis. Would it improve the sound if I clean up the wiring using harnesses and ties?
Old 24th August 2009, 05:19 PM   #2
Did it Himself
richie00boy's Avatar
Probably not unless some wire is close to a noise source such as transformer or high current parts/cables.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th August 2009, 08:10 PM   #3
AMV8 is offline AMV8  United Kingdom
You may have already done this but if not it will help a lot to keep signal wires away from power supply wiring.
The biggest wiring problems normally come from defective earthing. Avoid earth loops.
Don
Old 24th August 2009, 08:14 PM   #4
Thanks for the replies, what's the best way to ground the amp to avoid earth loop? I have Vgnd from the PSU to the AC Earth. Should I run AC earth to the chassis ground also?
Old 24th August 2009, 08:23 PM   #5
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I like to use star grounding - grounding everything back to a single point if possible.
http://www.geofex.com/Article_Folder...nd/stargnd.htm
http://www.aikenamps.com/StarGround.html
Jim J.
Old 24th August 2009, 11:46 PM   #6
alazira is offline alazira  United States
alazira's Avatar
Yes, AC earth must be grounded to chassis for your safety. PSU Vgnd should be connected to Chassis/AC earth via CL60 or disconnecting circuit to avoid ground loop hum.
Old 25th August 2009, 12:26 PM   #7
Formerly Thanh1973
Melon Head's Avatar
Your question is implying that you are not entirely happy with the sound of your amps.
Once you have sorted out your wiring issues, if you are still not happy with the result. Then I am sure we can sort out any other problem.
If signal wires have to cross power supply wires then make sure you do so at 90 degrees.
Also try and keep wires as short as possible while still being neat.
Old 25th August 2009, 05:15 PM   #8
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
My stuff always looks like tri-colored spaghetti.
Don't know how you guys keep your stuff so neat!
I build, therefore I am.
Old 25th August 2009, 06:58 PM   #9
Colescuttle's Avatar
Send a message via Yahoo to Colescuttle
Default What is CL60?
Old 25th August 2009, 07:16 PM   #10
max426 is offline max426  United States
max426's Avatar
http://search.digikey.com/scripts/Dk...name=KC006L-ND
4 wires to 1 RCA tail ?? metaverse Car Audio 5 14th January 2009 10:40 PM
ESL wires bshaw147 Planars & Exotics 1 3rd October 2008 08:41 AM
Twisting Wires....which ones ? redrabbit Power Supplies 2 24th February 2008 06:47 PM
Best way to combine wires? sts9fan Parts 0 28th December 2007 09:06 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Page generated in 0.11669 seconds (71.82% PHP - 28.18% MySQL) with 10 queries
