Where do you mount the thermistors (both at transformer and at GND)?
Mount them close to heatsink/body of amp or near the transformer? Any pics of it? |
#2 |
This is how i have done it. However I am a rookie at this so I would like to see other comments from experienced builders.
jim |
#3 |
The power supply thermistors are not used for temperature sensing but for inrush current suppression. They limit surge current when powering up the amplifier by functioning as a power resistor which drops from a high cold resistance to a low hot resistance when heated by the current flowing through them. They do not need to be close to a source of heat.
#4 |
If I am using a soft start circuit, I guess I will not need the Inrush Current Limiter?
Am I right on this one??? |
#5 |
I used this schematic, I wish I could give credit to whom it belongs. (I think it was Papa's from the F3 power supply) I just copied it. You are correct, if you have a different soft start circuit, you do not need the Themistors (in the startup circuitry).
Ron |
#6 |
thanks for the reply, understood
#7 |
#8 |
Additional question wrt thermistor and 240v transformer.
The PSU pic in the F5 doc that refers to 240v shows a dual 120v primary (top part of pic) ![]() If I only have a single 240v primary, is my alternate position correct (bottom part of pic) or am I going for a Darwin award? tia for any life saving comments anyone would like to offer, else I guess I'll find out when I power the PSU part up tomorrow ;-) cheers Nick |
#9 |
This is how i have done it in my F2 clone. However i am concerned that 10 Ohms series resistance does not reduce the inrush current enough. With a 240v supply and 10 Ohms series resistance (ignoring the resistance of the primary winding for now) the inrush current is 24 Amps. i am using a 625VA toroid and when i checked the resistance across the primary winding including the series CL60 thermistor it measured 14 Ohms. Is there a better way to measure the series resistance of the primary winding?
I'd like to hear some experienced voices on this issue... is a single CL60 enough with a 240V supply? Cheers, mymindinside |
#10 |
| How to choose a thermistor to protect power supply? | G | Chip Amps | 27 | 3rd March 2007 09:42 PM |
| Power supply component location. | HenryM | Chip Amps | 0 | 20th January 2005 05:53 PM |
| Thermistor use in power amp bias servo circuit? | mhb | Solid State | 7 | 19th January 2004 08:17 PM |
| Supply caps location in Bridgeclone | Ricren | Chip Amps | 4 | 25th July 2003 05:26 PM |
| Thermistor Location | awhiteguy | Parts | 12 | 15th November 2002 08:42 AM |
| Page generated in 0.09693 seconds (79.77% PHP - 20.23% MySQL) with 11 queries |
