Im building an F2 amp. I read a few posts in the F3 build thread about the output cap. Some say to use a good one, and don't bother w/ the bypass cap. I'm willing to try soldering 10-15 Silmic II's together, and the cost would be about the same as getting a decent bypass cap.
Any thoughts? |
#2 | |
#3 |
The one and only
Remember that current source amplifiers tend to ignore the
artifacts added by capacitors - those artifacts show up as voltage and do not tend to alter the current. |
#4 |
The artifacts of capacitors could be understood that they cause some small parasitic voltage, but almost no current, i.e. can not provide wattage. This makes more safe using them at an output than at input. But for listenable effects even tiny artifacts may play a role, something similar to effects of cables.
#5 |
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#6 |
how about voltage output amp like F3, 4, 5?
Is the output shown in the schematics AC values? Like 21v in F3? |
#7 |
Hmm... to be honest, I already ordered the 30 silmics before I posted this
Maybe I'll save them for a possible future f3 build, if it doesn't make as much difference in the f2. (ignorance isn't bliss.. it costs money!) Last edited by wicked1; 21st August 2009 at 02:09 PM. |
#8 |
Difficult, but most valuable thing is when one try variants, compare and report his impressions.
#9 |
I'm thinking about capacitors again today...
For this amp (F2), the input cap is still important, right? But not the output as much, as it's current that matters at that point. And so if the output cap doesn't matter much, why is the bypass needed at all? Because it matters a little, even though not as much as it would in a standard voltage amp? thanks again. |
| Bypass capacitor on ac lines help? | milen007 | Parts | 9 | 26th June 2008 05:07 PM |
| Choosing A Cathode bypass capacitor | alexmoose | Tubes / Valves | 11 | 7th April 2007 09:14 AM |
| bypass capacitor | omni | Parts | 5 | 17th July 2006 12:03 PM |
| bypass capacitor source | omni | Parts | 1 | 16th July 2006 08:28 PM |
| Does a cathode bypass capacitor reduce hum? | ray_moth | Tubes / Valves | 23 | 21st August 2004 01:38 AM |
| Page generated in 0.12040 seconds (65.92% PHP - 34.08% MySQL) with 11 queries |
