cviller board rev 1.0, has markings blacked out.
contrary to board markings using my meter it would appear the proper orientation of a ZTX550/ZTX450 in Q5/Q6 http://www.diodes.com/datasheets/ZTX550.pdf http://www.diodes.com/datasheets/ZTX450.pdf would be like this?? ![]() ![]() but not sure... can someone with experience advise me? Don't want to solder till i'm 100% thanks for your help. tal |
#2 |
You are right, CViller's board is footprinted for BCS transistors which has the opposite orientation of the ZTX transistors. It's mentioned in his F5 build guide. Also, you might want to remove the current limit circuit which includes these transistors after you get it working. It sounds better.
#3 |
Thanks very much, I thought they must need to be postitioned this way; but just wanted to see if i was more confused than usual.
thanks for the info and opinion; i'll look into the current limit mod after i get her running. cheers, tal |
| Driver orientation for T/S parameters | Buzzy | Subwoofers | 2 | 7th May 2008 02:39 PM |
| Port And Driver Orientation? | jpvt68 | Subwoofers | 7 | 7th April 2008 10:30 PM |
| Looking for a copy of Adireaudio's Driver Orientation pdf? | TimA | Subwoofers | 3 | 2nd August 2007 12:02 PM |
| Bi-Radial horn tweeters - what's the proper orientation? | KT | Multi-Way | 2 | 29th January 2005 05:56 PM |
| Isobaric driver orientation: which is best? | Javaman | Multi-Way | 25 | 1st January 2002 12:20 AM |
| Page generated in 0.06793 seconds (70.76% PHP - 29.24% MySQL) with 10 queries |
