Old 11th August 2009, 05:38 PM   #1
Nikolas Ojala's Avatar
Question Class A push-pull
This is especially for Mr. Nelson Pass, but anyone who knows may answer.
I read this article written by Nelson Pass: http://www.firstwatt.com/downloads/seclassa.pdf
He wrote:
Problems with push-pull amplifier designs associated with crossover distortion have been discussed elsewhere at length, and one of the primary results is non-monotonicity. Class B and many AB designs have distortion products which dramatically increase with decreasing signal. This is reduced greatly by Class A mode, but crossover distortion remains as a lower order discontinuity in the transfer curve.
I emphasized the important sentences.
Some questions arise:
  • Is that a known feature of Class A push-pull amplifiers?
  • How does it appear in distortion measurements?
  • Any references for further study?
All distortions are not equal.
By the way: I hate overuse of acronyms.
Old 11th August 2009, 07:26 PM   #2
The one and only
Nelson Pass's Avatar
Default Re: Class A push-pull
1) Yes, although it is greatly reduced and it depends on the specific
design, bias, power and load.
2) It shows up as harmonics greater than 3rd at higher power levels
3) "Leaving Class A" at www.passlabs.com discusses some of the issues.
Old 24th August 2009, 10:10 AM   #3
tiefbassuebertr's Avatar
The significant difference in sonic quality between "single ended class A" and "push pull Class A" by commercial devices is in my opinion due to the fact that the so-called "push pull Class A" in real life is often push pull class AB. Just because the area where will be leaving the Class A mode, is a little above typical values arround 30 to 50 mA (e. g. 100-300mA), some manufacturers already believe that they offer "pure Class A" amplifier.
Old 24th August 2009, 11:55 AM   #4
AndrewT is online now AndrewT  Scotland
every amplifier produces distortion along with the signal in the output.
The advantage of a ClassA amplifier is that is has Zero Crossover distortion. It still has all the other distortions and noises etc. It very specifically addresses one distortion issue.
Single Ended ClassA has a hard current limit. The ClassA limit = peak output current limit = output stage bias current.
Push Pull ClassA has a "ClassA" current limit. The ClassA limit = twice the output stage bias current.
But a major difference, (I'll let you decide if this could be interpreted as an advantage) between Single Ended and Push Pull is that the PP can deliver peak output current that can very significantly exceed the ClassA current limit. Appropriate design decisions can use this ability to give performance improvements that ClassAB and SE cannot achieve.
regards Andrew T.
Old 24th August 2009, 12:31 PM   #5
I agree with all mentioned things except of the last sentence:
Are there topologies about such designs? Please let me know
Old 24th August 2009, 12:58 PM   #6
all right, you can have that opinion.
Tell me, how does a SE give peak current that exceeds the bias current in signals of both polarities?
I consider that to be an advantage of PP, particularly when driving reactive loads (all speakers). Highly reactive loads demand even more peak current on fast starting/stopping transients. A recent post showed experimental data for real speakers with real music signals where the peak transient currents were approaching five times the current predicted by the nominal resistive impedance of the (commercial) speakers included in the testing.
Tell me how a ClassAB amplifier can completely eliminate the crossover distortion that is inherent in the topology?
Now, I'll give a simple example of a PP 75W ClassA amplifier where both these limitations are to some extent overcome.
Take a 10pair output stage running on a +-40Vdc PSU. Re=0r1, optimum ClassAB bias per device ~220mA.
Total ClassA bias 2.2A. Peak ClassA output current ~4.4A
Dissipation ~180W/channel, ~18W /device.
Peak transient output current >20A into 1r5
This is a pure ClassA 75W amplifier (for 8ohm loading) that can drive upto 5times nominal maximum current into a reactive load and has Zero crossover distortion while within it's ClassA 75W rating.
Show me a 75W into 8r0 SE or ClassAB amplifier that can achieve both these criteria.
regards Andrew T.
2A3s in push pull; class A Sir Trefor Tubes / Valves 39 30th January 2011 10:03 PM
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 26th May 2010 11:05 PM
Class A, push pull amp using transistor space2000 Solid State 18 7th August 2008 02:53 PM
Class A Push Pull with 6L6GC d1camero Tubes / Valves 9 4th December 2007 08:35 PM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 11:52 AM
Page generated in 0.11129 seconds (81.50% PHP - 18.50% MySQL) with 10 queries
