Big torrid's, with wrong voltages.
Old 9th August 2009, 05:36 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Unhappy Big torrid's, with wrong voltages.
Hi all...
I was in (Sort off) luck getting such two X-former's, real big size, 1000VA @ 24 0 24 vac.
Any suggestion's what to do with them? - Input appreciated... - PowerAmp preffered ofcause.
I am not interessted in unwinding them, please
Only schm. i found using such voltage, was the Aleph60, but i rather would strip the DC-rail down to 22~25v if it's possible ? - Is there any way of doing that in a PSU ?
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 9th August 2009, 06:06 PM   #2
DougL is offline DougL  United States
2 suggestions, one of them serious.
The Zen V5 Power supply could be adapted for F4 or F5 with those transformers.
Alternately, using that transformer with a couple of chokes would make a great choke input PS. This will reduce the voltage from 1.4 V(trans) to about .9 v(trans) and have a more constant current draw. If only the transformers weren't 5 Lb each and cost about $150 a pair.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 9th August 2009, 06:39 PM   #3
lykkedk's Avatar
Thank's DougL, i have just found the paper's of the Zen5 PSU, and is looking really interessting. - Will for sure be reading the paper's soon.
Regarding the other suggestion:
You mean ?? - $150 for thoose x-former's i got ??
Jesper.
Old 9th August 2009, 07:56 PM   #4
I was talking about the inductors for the choke input.
Here is an example of what might work: C-59U
Triad Magnetics
Inductor; Filter; Ind 0.01H; Tol -20%, +50%; Cur 12.5A; Lug; DCR 0.1 Ohms 6.25 lb
And they are about $60 at Allied.
Triad data sheet
If you need to see the Power supply, I have it simulated in PSUD2.
Doug
Old 9th August 2009, 10:33 PM   #5
xcel is offline xcel  Netherlands
xcel's Avatar
The VA and AC ratings are excellent for building a power supply for an Aleph-X ......And I mean a big one !!
Xcel
Less is more, more or less ...
Big torrid's, with wrong voltages.Hide this!Advertise here!
voltages on a zen v.9 gionag Pass Labs 5 28th May 2008 03:42 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
ESL voltages Fanuc Planars & Exotics 5 11th February 2006 07:36 PM
trying to find a torrid soundNERD Chip Amps 9 20th March 2005 11:05 PM
TV set voltages? setmenu Everything Else 10 20th March 2003 01:36 AM
Copyright ©1999-2017 diyAudio
