Old 9th August 2009, 04:26 PM   #1
Default Acceptable Ripple Current for Aleph 2
I have 3X47000uf caps per rail and want to build either a CRCC or a CRCRC PSU. I have played with PSU Designer 2 and can get the ripple down to less than 10 mv with a 1ohm R between the first 2 caps and a .1ohm R between the next 2. What is acceptable ripple and is there an issue using larger value eg 1 ohm resistors ( Ihave 50v at the rails- so can live with the voltage drop and their 50w rating means that heat is not an issue). Any advice gratefully received.
Old 9th August 2009, 05:47 PM   #2
The one and only
Nelson Pass's Avatar
What's the ripple rating of the caps? The first set off the diode
bridge will see most of the action.
Old 9th August 2009, 06:42 PM   #3
The Ripple Rating is 14.5A per cap.
Old 9th August 2009, 10:35 PM   #4
xcel is offline xcel  Netherlands
xcel's Avatar
I allways consider 10 mV ripple under load as a really nice figure....
Xcel
Less is more, more or less ...
Ripple current ? woody Solid State 2 12th January 2009 10:09 PM
Ripple current in capacitors. beppe61 Power Supplies 5 3rd September 2006 11:37 AM
whats ripple current of c johndiy Solid State 9 2nd September 2006 11:37 AM
acceptable amount of ripple for AlephX PS nobody special Pass Labs 4 27th February 2003 08:56 PM
Acceptable Aleph Ripple? dshortt9 Pass Labs 1 15th July 2002 09:56 PM
Page generated in 0.09043 seconds (59.02% PHP - 40.98% MySQL) with 10 queries
