diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Pass X250+ Wadia (http://www.diyaudio.com/forums/pass-labs/148492-pass-x250-wadia.html)
martev 3rd August 2009 03:11 PM
Pass X250+ Wadia
Hello !
It successfully to using Wadia with variable output and Pass X250 or is better when has pre amp in system?
Thank you !:cool:
Zen Mod 3rd August 2009 03:49 PM
if Wadia have enough juice (read - volts) then you don't need preamp
Nelson Pass 3rd August 2009 04:12 PM
Mine has enough juice to drive a Lowther by itself.
:cool:
KevinHeem 4th August 2009 07:26 AM
Re: Pass X250+ Wadia
The Wadia can output up to 4.25V, and has an output impedance of less then 15 ohms. So I'm pretty sure it will drive the X250 where ever it wants to go. Personally, I love the Wadia players direct to amp. Recently heard Wadia 781i > X250.5 > MG 20.1, probably the most enjoyable 90 min. I've ever spent listening to recorded music.
Take Care,
Kevin
martev 6th August 2009 08:44 AM
Thank you !!!
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
