Threshold S/500 bias set up anyone?
Old 4th August 2009, 02:37 AM   #21
ANADIGIT is offline ANADIGIT  Europe
Banned
Default he he he
I also have original and cloned S/550E.
My PCB that I shown was made my me but I put it in original S/550E substitute which one broken from SPARK !
Does anyone interested this completed PCB ?
Anadigit
Old 6th August 2009, 07:32 AM   #22
stevieg123 is offline stevieg123  United States
Default Could use some more advise please!!
Hey everyone, while waiting on getting my new (to me) ML Ascents fixed, whole other story, anyway, I decided to go ahead and remove the "good" channel from my S-500 to remove and replace thermal compound between outputs and sinks. Much to my surprise when checking the outputs I found an "N" with a dead shorted EB junction!!! And I mean dead short, 0.6 ohms!!! This channel still worked, on scope it worked as well as the repaired channel, exact same AC output voltage when driving 8 ohm loads just below clip!!! I checked this after fixin the obviously blown channel. Not blowing rail fuse. Perfectly symetrical clipping of both channels. Anyone ever see this? I've never repaired an amp, any amp, that would still work with one output with a dead shorted EB juction on an output. All 0.1 ohm emitter resistors ok. None open. Reccomendations anyone for next step of troubleshooting? Have some time as getting order together for Mouser, etc, as I now need some more 15024 & 5's to pick thru.
Thanks in advance, Stevie
Old 29th January 2010, 02:41 AM   #23
Banned
Default S/550E for PA
This's my S/550E with PA version I cloned PCB from my S/550E last year but I changed supply rails to DUAL SMPS MODULE.
Anadigit
Old 29th January 2010, 07:33 AM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Hello Guys ,
Is the bias voltages the same on Series 1 and Series II ? one of my 500's series II , never get's beyond warm at low to moderate levels and stays cold if left idling .
regards,
Old 29th January 2010, 09:06 PM   #25
Hi a.wayne, I've tried twice to post a reply to you, email me at steveandvic@sbcglobal.net and I'll try again. Steve
Old 29th January 2010, 09:13 PM   #26
Sin Bin
Will do ....
Old 29th January 2010, 11:16 PM   #27
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You are certain that you are not simply measuring the PN
junction? Many voltmeters read that as .6 or .7 ohms.
Old 30th January 2010, 06:27 AM   #28
Hey Nelson, are you talking my old post where I found a shorted output on the working channel? Steve
Old 30th January 2010, 04:17 PM   #29
The one and only
Yes.
Old 24th August 2016, 06:06 PM   #30
billnavas is offline billnavas  Greece
A photo of pcb please from up and more down side
Threshold S/500 bias set up anyone?Hide this!Advertise here!
Adjusting the BIAS for Threshold SA3 sonic22 Pass Labs 9 16th May 2011 01:38 PM
Threshold SA4/e bias nchelazzi Pass Labs 2 16th June 2008 09:10 PM
Threshold S/550e Bias advice Barry1 Pass Labs 0 28th April 2007 03:09 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Pass Labs 4 18th January 2005 07:49 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Solid State 15 17th January 2005 02:30 AM
Copyright ©1999-2017 diyAudio
