schematic variation and sim results  of Pass "X" series US pat 5376899 schematic variation and sim results of Pass "X" series US pat 5376899 - Page 2 - diyAudio
Old 29th July 2009, 10:01 AM   #11
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Four unbal. power amp bal versions based of Pass "X" (SuSy) with sim. results (Fig. 3 from US patent 5376899) continued
C: Pass X bal Fig3 Var III
Gain=10x: 40=20R 36/37=11K3 Open-Loop Gain: 83x In/out 1V/10Vss
1) schematic for Damping factor test
2) AC-Analysis (damping factor over frequency)
3) AC Analysis (normally frequency response)
4) Fourier Analysis lin 10 KHz (THD) K3: 1,65mV
5) Fourier Analysis log 10 KHz (THD)
6) Fourier Analysis lin 100 KHz (THD) (K3: 16mV)
7) Fourier Analysis log 100 KHz (THD)
8) Fourier Analysis log 19/20 KHz (IM)
9) Transient Analysis 1MHz
10) schematic
Old 29th July 2009, 02:29 PM   #12
Pass X Var I (unbal) versus X Var V bal (only THD, 10KHz + 100KHz) US patent 5376899
Gain=10x In/out 1V/10Vss
A: Pass X-Var I.unbal Fig3 THD 10 100KHz.pdf
1) THD 10KHz
2) Schematic
3) THD 100KHz
File Type: pdf c .pass x-var i.unbal fig3thd 10 100khz.pdf (22.6 KB, 115 views)
Old 29th July 2009, 02:36 PM   #13
Gain=10x In/out 1V/10Vss - continued
B. Pass X Var V bal Fig.3 THD 10 100KHz-.pdf (40 = 10R, Open Loop Gain = 125)
1) THD 10KHz
2) Schematic
3) THD 100KHz
good to observe is the THD compensation effect by balanced version, even by 100 KHz. Only third harmonic there are, that means at same time, there are no unwanted 1KHz signal by IM measuring by 19+20 KHz
At next I will investigate the complementary-symmetry (push-pull) version of Fig. 4 from US patent 5376899 both unbal and bal. versions
Let's see, whether it is possible to get a design based to this and to the CSPP topology (circlotron) with even more reduction of distortion.
File Type: pdf c .pass x var v bal fig.3 thd 10 100khz-.pdf (26.1 KB, 156 views)
Old 30th July 2009, 08:33 PM   #14
stinius is offline stinius
Originally posted by Nelson Pass
Play nice, you boys.
Don't make me come over there.
Nelson
You are welcome to come over here anytime you like, do some salmon and trout fishing and walking in the mountains, maybe some deer hunting.
Bring JC as well, it wouldn’t harm him if he rested his eyes on something else than the scope.
Cheers
schematic variation and sim results  of Pass "X" series US pat 5376899Hide this!Advertise here!
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 4 9th July 2012 02:25 AM
Results of waveguide "measurements" not so good ... paulspencer Multi-Way 15 2nd January 2010 03:52 AM
Aleph 4 - Simulation Results from "Circuitmaker" tiefbassuebertr Pass Labs 0 17th July 2009 11:53 PM
Copyright ©1999-2017 diyAudio
