Pass Shunt Circuit - Page 2 - diyAudio
Old 15th July 2009, 10:53 AM   #11
3V and 60mA to 80mA for a 2sk170.
What are you trying to do with the 2sk170?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th July 2009, 03:00 PM   #12
Bengali is offline Bengali  United States
You could use the similar circuit for lower voltage. Like 3 Volt. If you replace transistors with BJT, Bipolar.
This will give a voltage drop from B (=zener) to E (output) like -0.7 Volt only.
With very small changes depending on current drawn.
Depending on how much current you need you can select suitable devices.
For <500 mA then BD139 and BD140 would work well.
For higher currents we can use MJE15030/MJE15031
thanks. that was also suggested to me. I decided to keep it simple and use the LM317/L337.
I posted the circuit on the jboz postings. 60-80mA is total,
it will be driving 7 channels, 7 seperate 2sk170's.
I'm boosting the line level from my AVR to my external
amp. Too much loss from my maggies. Battery power
version has been built up and sounds just wonderful.
so I've been looking for a very low noise +24V & -3V
psu to power it.
thanks
Old 15th July 2009, 03:31 PM   #13
lineup is offline lineup  Sweden
lineup's Avatar
That is a good choice.
Will give a very precise voltage.
I have used LM317 many times.
These 3-pin regulators are very easy to work with after you have done it a couple of time.
lineup
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
shunt regulator using VR tubes (with ccs like g pimm) and circuit load jarthel Tubes / Valves 2 23rd April 2007 03:33 PM
EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? jarthel Tubes / Valves 27 9th June 2006 12:04 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
Copyright 1999-2017 diyAudio
