PASS-YAX2-JH pcb.
A little playing with board maker - here is the result.
Pls. for comment or suggestion!
jazzy
Check the whole Size for the T03
It looks to me that the whole size is to small for the standard lead. The leads are about .040" so the whole size should be about .045". If these are plated through, you should consult with the the PCB vendor about the loss in diameter from plating.
James
