ALEPH 2 Service Manual
Just to add this is one of the best Amps you can build, period! I built may pair back in 2004 and in the interim have built many other Amps including Krell KSA-50 and KSA-100 and have also owned several other expensive amps. And where do I always end up at...? Back listening to my Aleph 2's. They are absolutely magical. But to get the most out of them you must also have balanced preamp and balanced source to feed in. Otherwise you will never get all the magic out of the amp!
P.S., You should buy stock in aluminum extrusion company. You going to need ALOT of heat sinks. Mine has same heatsinks as Krell KSA-200!
