Aleph printed circuit boards alternative
Old 19th December 2001, 10:41 PM   #11
hifi is offline hifi  Sweden
is that the original layout??...
Old 19th December 2001, 10:47 PM   #12
you cant publish the "original" so one could etch his own boards ....i wounder cuz i would like to redraw some things ...
/micke
Old 21st December 2001, 04:07 PM   #13
grataku is offline grataku  United States
xcel,
nice work, you should definitely come up with a price figure here.
Also, it would be nice if you posted the component list, with the model type especially for components of variable size like caps and resistors. What is the distance center to center between the terminal of the PS capacitors? What is the MAX diameter of the cans one could fit underneath?
Old 21st December 2001, 08:16 PM   #14
xcel is offline xcel  Netherlands
xcel's Avatar
Originally posted by grataku
xcel,
Grataku,
Thanks for the compliment ! I"ll send you a price figure. My components are pretty ordinary, and so are their shapes and sizes. I can give you the manufacturers list of all components but that's not really necessary since I've used standard components. The holes in the PCB's are large enough to handle any component from any manufacturer. I don't want to be restricted to just one component supplier, you see. What I can tell you is that I use components from Philips (capacitors, diodes and resistors), MOSFET's from International Rectifier (IRF), Siemens (capacitors,NTC's).
The mounting holes for the capacitors are 30 mm apart, measured from centre-to-centre. The diameter of the holes are 6 mm, because of the fact that the screws are M5. My capacitors are 65 mm (diameter)x105 mm (height). They don't make 'm much larger than this. But to answer your question, the maximum diameter of a capacitor for this board can be 90 mm !!
Seasons Greetings,
Xcel
Old 21st December 2001, 08:21 PM   #15
xcel's Avatar
/micke
I certainly have no intention to publish my boardlayout. It would be useless because of the double sided nature of the main board.
Xcel
Old 21st December 2001, 09:05 PM   #16
why ? ... i would have no trouble in manufacturing a double sided pcb?...
/micke
Aleph printed circuit boards alternativeHide this!Advertise here!
Aleph 2 Printed Circuit Boards (PCB) opc Swap Meet 5 24th April 2005 02:58 AM
Printed Circuit Boards for DIY Audio dmfraser Parts 8 3rd August 2004 10:52 PM
Deteriorating printed circuit boards. RADIOLEE Parts 3 20th August 2002 03:01 PM
Printed Circuit Boards - 4 layer thylantyr Solid State 3 18th August 2002 12:28 AM
Aleph printed circuit boards xcel Pass Labs 6 20th September 2001 03:49 PM
