hi all
i,ve heard you can mod an aleph 5 with a jfet front end and would like to try can any one here offer any advice on how its done and what parts to use also what is the limit for the supply voltage on a aleph 5 assuming the heatsinks are up to it ,im running a 25-0-25 at the moment regards sheafer |
#2 |
this may help, you'll want to limit the rails to +/-24v
#3 |
thank you kind sir i will check it out
regards sheafer |
#4 |
Zen Mod has made a jfet frontend for (me - Thank you, Zen Mod - and) an Aleph 60 here:
jfet input aleph 60 It can be driven using a little higher supply voltage. |
#5 |
The one and only
The 2Sj74's and their duals the 2Sj109's seem to be able to withstand
35 volts in actual amplifiers, which puts them in striking distance for the Aleph 5. To keep the dissipation low on the JFETs, you want to reduce the bias current to about 5 mA each, which is accomplished by raising R11 from 221 to 475 ohms. This keeps the Vds at about 30V and the dissipation at 150 mW each. R12 will then want to be about 820 ohms, and it would be a good idea to place a resistor in series with the Drain of Q2 at 820 ohms also. This works, but it does operate the JFETs at the limit, so don't fool around and do try to keep the Jfets cool. Paralleling two for Q1 and Q2 is a good idea also.
#6 |
> Paralleling two for Q1 and Q2 is a good idea also. Does it not change the open loop frequency characteristics ? Patrick |
#7 |
thanks guys
you are very helpfull regards sheafer |
#8 | |
The one and only
| Aleph X alu front and heatsinking | jojo | Pass Labs | 11 | 26th October 2005 07:31 PM |
| searching software to switch front speakers to rear and rear to front!-dolby surround | MCM | Everything Else | 6 | 6th February 2004 09:29 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Please help me check the Aleph Front end PCB Layout | acliao | Pass Labs | 5 | 20th June 2002 07:58 AM |
| Aleph's front end separate power supply | Peter Daniel | Pass Labs | 24 | 10th April 2002 09:48 PM |
| Page generated in 0.11594 seconds (65.82% PHP - 34.18% MySQL) with 11 queries |
