Old 28th June 2009, 12:38 AM   #1
NV&H is offline NV&H  United States
Default F5 Single Primary Transformer
Made an error and ordered (and received) a transformer with only a single primary winding instead of two, as shown in Nelson's article.
Is this transformer unusable? Is my issue an inability to avoid startup surges?
NV&H
Old 28th June 2009, 02:54 AM   #2
labjr is offline labjr  United States
Default Re: F5 Single Primary Transformer
How did you make that error? You really need two secondaries. What is the voltage? What is the VA Rating?
Old 28th June 2009, 03:13 AM   #3
bobodiouosso has a circuite that might work for you it's post
# 4290 in the F5 thread.
Old 28th June 2009, 03:24 AM   #4
I've got 2 secondaries at correct voltages. Capacity is fine at 400VA. Just a single 120V primary. That's the problem. Trying to understand how big of a problem.
What happens if I have just a single 120V primary???
NV&H
Old 28th June 2009, 12:05 PM   #5
Oh, I thought you meant secondaries. I don't know what you could do except to use a stepdown transformer.
Old 28th June 2009, 01:48 PM   #6
tinitus is offline tinitus  Europe
Should be perfect
Double primaries is only to have the option of both 120Vac and 240Vac
And you dont need that
You have the best you could possibly get for 120V mains
Old 28th June 2009, 01:53 PM   #7
AndrewT is online now AndrewT  Scotland
Is France on 220Vac?
Why order a 110Vac transformer?
You do not need twin primaries.
You need a 220/240Vac primary.
regards Andrew T.
Old 28th June 2009, 02:48 PM   #8
ouch, I just looked at the US flag
Different situation then
Old 28th June 2009, 03:03 PM   #9
Hi T,
that's why it more helpful than saying "countryside".
regards Andrew T.
Old 28th June 2009, 03:59 PM   #10
Hi T,
Or scottish border
Maybe just give proper basic information when asking
Anyway, If he doesnt know his mains voltage theres still a long way to go
Sorry NV, Im not making fun of you
But sometimes its best to know actual voltage on mains and not just what it should have been
Sometimes its a teaser and may make it tricky
You may not know the exact voltage of your supply until you have built and connected it
Sound like your first build, so you may need new trafo
Im not sure whether you can manage anything else
Though, one advantage of a 120v-120v primary, over a 240V, is that you can rewire it, if you move back to USA
Can I use a single primary 120V transformer with 240V? hershann Power Supplies 6 24th January 2008 02:02 PM
Using transformer primary as an autoformer stoolpigeon Everything Else 8 22nd April 2007 06:17 AM
Trafo- 225VA , single 117V primary, Dual 40V secondaries Illusus Swap Meet 3 11th December 2003 04:07 AM
Page generated in 0.11234 seconds (75.03% PHP - 24.97% MySQL) with 10 queries
