F5 Single Primary Transformer
Old 28th June 2009, 05:33 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
BMM have nice 230V Amplimo trafos
sometimes we know very little, and sometimes we know too much
Old 28th June 2009, 09:02 PM   #12
NV&H is offline NV&H  United States
It will be used in the US. Again, everything is as specified by Nelson's F5 article except for the single primary winding. For 120V operation, Nelson's design shows twin primaries (in parallel with caps and thermistors bridging across).
Can anyone tell me what kind of problem I'll have with a single primary winding? Yes, it's a first build for me.
NV&H
Old 28th June 2009, 09:52 PM   #13
labjr is offline labjr  United States
The reason for dual primaries is so you can configure the transformer windings for use almost anywhere in the world. If you have a single primary which is 120V, you can use it in US but not France. If the primary voltage is 220 then you can't use it in USA.
Get the picture?
Old 28th June 2009, 10:21 PM   #14
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
If you connect it to the 240V main, you might get 2 x 36Vac in secondaries, but with allowance of halved maximum current.
And, you should check if the transformer is made not only for 60Hz-main (in USA?), but also for 50Hz-main (in France?).
Old 28th June 2009, 10:48 PM   #15
Maybe we are assuming you have a 120v primary when you have a 230Volt one. What is the primary voltage?
Old 28th June 2009, 10:57 PM   #16
Get the picture?
That's it?? When I saw the twin primaries Nelson uses for his commercial F5 with the twin thermistors with the cap jumping across, I assumed there was more to it than that. If not, I'm certainly happy with that. I guess it would be beneficial to Nelson if he can use the same transformer model whether its for domestic use or export!!! Silly me.
Thanks for everyones help!!
NV&H
F5 Single Primary TransformerHide this!Advertise here!
Can I use a single primary 120V transformer with 240V? hershann Power Supplies 6 24th January 2008 03:02 PM
Using transformer primary as an autoformer stoolpigeon Everything Else 8 22nd April 2007 07:17 AM
Trafo- 225VA , single 117V primary, Dual 40V secondaries Illusus Swap Meet 3 11th December 2003 05:07 AM
