#311 |
The Farnell socket looks like it's a better quality - at times, you do more or less get what you pay for. Instead of removing contacts (a direct solution - I still may do that), I marked the socket with white splotches indicating orientation). I may still amputate contacts... Chop, chop (think first, chop later...)
Last edited by wrenchone; 16th September 2011 at 05:07 AM. Reason: snarky postscript |
#312 |
Thanks for the info - that makes it easy now - off to market and get sock(et)ed!
... jh |
#313 |
Hi everyone,
I've spent a little time this afternoon fiddling with one of my versions of this preamp, and I found something I don't understand. (Again....) Referring to the schematic in post #28, C4 (with C10, C11) and R9 (with the input impedance of whatever it's connected to taken into account, I guess) form a high-pass filter, blocking any DC. (Right?) But what is R20's role? Is it a "safety resistor", as NP referred to something similar in his B1 article? And if so, how do you decide on its value? I notice that Juma changed the original 33R to 15R in the 2SK170 version in post #283, but why? Apart from just wanting to understand, I would like to switch R20 for something a bit better quality I have kicking around, and am wondering what replacing the 33R with 56R would change (except for some loss of volume, I presume). I should add that I am not using C10/C11, and have a 10uF polypropylene in place of C4. I could just try it and see, of course, but I like to understand things when possible. Regards Nigel |
#314 |
R20 is there to isolate the input capacitance of the next stage (including interconnects). We don't want to load the preamp with pure capacitance...
#315 | |
Hi Juma,
Is 33R just a sensible balance between "not loading with pure capacitance" and not losing too much gain? If so then 56 R should work just fine, right? Regards Nigel |
#316 |
two 56R in parallel are even better
![]() just take it as counter measure for ultrasonic oscillations , and (inter)connecting procedure safety don't go above 33R - it directly adds to preamp output impedance
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#317 | ||
Hi ZM,
Unfortunately I only have two of them - they were left over from another project. Not a problem - I was hoping to fire up my soldering iron and tweak the preamp a little this evening, but I can always put a couple of 33R on my next parts order and do it some other time. Quote:
Regards Nigel |
#318 |
well - put there anything from 10 to 47 Ohms
whatever you have in drawer
#319 | |
Regards Nigel |
#320 |
it depends ;
if next stage ( amp ) isn't current hungry ( low input impedance and/or capacitance ) , everything up to 100R is OK maybe best thing for test is to put shortie instead ; that's best resistor - isn't it ?but - I'm not expecting that you are going to hear too much difference
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
