BF862 Preamp BF862 Preamp - Page 29 - diyAudio
BF862 Preamp
BF862 Preamp
Old 13th August 2010, 05:05 PM   #281
juma is offline juma  Germany
juma's Avatar
Originally Posted by kp93300 View Post
...Can i substitute all these for 47 uF ?
...Can i substitute BC 548c with BC 548B and BC 560 C with Bc 560 B.?
Yes - to both questions.
Old 18th August 2010, 02:27 PM   #282
kp93300 is offline kp93300  Malaysia
Default Power supply specifications
Hi Juma,
i assembled the negative rail and has a voltage of -4.75 V dc at the output. Is this acceptable?
I like the power supply very much and made another one for my dac that requires 18V dc. The dc after rectification is only 22V and after the salas shunt i have a 18.8 V . There is only 3.2 V difference .
Can this shunt work well ?Sorry, I do not have a scope to tell.
Thank you in advance .
kp93300
Old 12th August 2011, 06:14 PM   #283
juma's Avatar
I received a request for version of this preamp that uses 2sk170BL (Idss about 9mA). Right now k170 is easy to get and BF862 is a SMD component (not convenient for old hands and eyes ), so here is the schematic.
The gain is a bit higher (9 dB) and the PSU is a bit different (be exact with input DC voltages +28V and -8V).
Old 12th August 2011, 08:23 PM   #284
dobrivoje is offline dobrivoje  Serbia
Now we have BF862 preamp without BF862.
This reminded me of my late grandmother. She didn't like coconut, so she has been making coconut flour rolls without coconut flour.
Old 12th August 2011, 10:35 PM   #285
juma's Avatar
Originally Posted by dobrivoje View Post
... coconut flour rolls without coconut flour.
So, what did she use instead of coconut flour ?
Old 13th August 2011, 11:33 AM   #286
juma's Avatar
Those who have already built B1 and just need some additional gain, can add just the gain stage (and the PSU) in the existing box. Coupling cap (C3) is not needed if your B1 already has one at the input.
Old 13th August 2011, 12:33 PM   #287
Wheat flour. The taste was something between sweet bread and bicycle tire.
Old 13th August 2011, 02:54 PM   #288
juma's Avatar
Wheat flour. ...
Wheat flour is a basic part of the recipe anyway and spicy coconut flour was left out unsubstituted.
It looks like we don't have an analogy with this preamp ...
Old 13th August 2011, 05:58 PM   #289
Russellc is offline Russellc  United States
BF862 Preamp
Wow, thanks I think I will try this. Do the sk170 jfets need to be matched?
Are you saying this needs its own power supply, or is it fed off the existing one?
Russellc
Old 13th August 2011, 06:20 PM   #290
juma's Avatar
If you are talking about gain stage from post #286 it's just one JFET per channel, but both channels should be same.
It needs -3.3V and +24V (both very, very clean, the neg. rail especially).
Gain stage is designed to use 2sk170BL with Idss about 9mA (8-10mA). Voltage of neg. PSU is chosen for amount of gain we aim for and Idss of JFET at hand. That determines the Rs and Rd too. I always aim for Id between 70% and 90% of Idss.
BF862 PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Copyright ©1999-2017 diyAudio
