BF862 Preamp
BF862 Preamp
Old 17th May 2010, 06:23 PM   #221
Samuel Jayaraj is offline Samuel Jayaraj  India
Since I want to have an input selector (relay based), I am inclined to go with the buffer as the first stage, followed by volume pot and then the gain stage, which should have a sufficiently low output impedance to drive the interconnect to the power amp.
Sam
Old 17th May 2010, 06:48 PM   #222
R.I.P.
Originally Posted by Jen-B View Post
Hi Andrew, you missed my underlying point,
I did not miss your underlying point.
I agree with and did not quote the parts of the post that were not controversial.
The problem was the advice you gave and I quoted, about locating a buffer in front of a pot.
regards Andrew T.
Old 17th May 2010, 06:52 PM   #223
R.I.P.
no.
Gain stage first if some of your sources need it, then pot/attenuator, then buffer to feed the interconnects.
The pot then has the opportunity to attenuate the noise created in the gain stage.
If any of your sources cannot drive the cables and the relay audio pins and the pot then fit a buffer or gain stage at the sources that are incapable.
Then the pre-amp will not need any gain stage, just a buffer.
If the gain stage is guaranteed stable with gains of +0dB, +6dB and +12dB, it would be nice to have a switchable gain stage, for 1times, 2times and 4times. That covers almost every source you are likely to want to connect up.
regards Andrew T.
Old 17th May 2010, 08:23 PM   #224
Jen-B is offline Jen-B  United Kingdom
Originally Posted by AndrewT View Post
...the parts of the post that were not controversial.
The problem was the advice you gave...
Controversial? Me?
Problem advice? Me?
Well Andrew you sound like a frustrated engineer in a meeting where he thinks everything must be done his way! Good luck with that!
(And I bet you really want to reply to this post justifying your position...)
Old 18th May 2010, 03:31 AM   #225
I sure don't intend to start a controversy here. Both approached have their merits and compromises. Let's give it a while. I'll come back with what I find out in the practical situation. Thanks again.
Sam
Old 31st May 2010, 07:30 AM   #226
vzs is offline vzs  Europe
Hi! As I can not find in local shops IRF9620 nor IRFP044 can I use IRF9610 and IRF610 for both positive and negative supplies as in the schematics of Salas at #84. Did someone used those?
Thanks!
Old 31st May 2010, 12:53 PM   #227
juma is offline juma  Germany
juma's Avatar
Originally Posted by vzs View Post
...can I use IRF9610 and IRF610 ...
They'll work all right.
Old 9th June 2010, 06:05 PM   #228
BFNY is offline BFNY  United States
hate to tread into the muck, but, why not.
I can see reasons for doing it the way you suggest. Not all sources have low output impedance, but are happy driving a reasonable load, i.e. 100-200k. And this load will determine the low frequency cutoff point in combination with the source's output coupling cap, almost always located after the output stage.
It's not always convenient to add a buffer to the output of the source. Especially in a case where a friend may bring over a classic and pricey vintage source made 40 or 50 years ago. This would include reel to real and cassette decks, FM tuners, phono pre-amps, etc.
So why not just use a 100k or 250k pot?
The higher thermal noise related to the higher pot resistance is one reason, probably a minor one.
The pot will have max. output impedance at the midpoint -The output impedance is the parallel combination of R1 and R2, i.e. Zout = (R1 * R2) / (R1 + R2). So for a 250k pot, Zout will be 62.5k, and driving the next stage, a jfet gate.
So what?
Jfets don't like to be driven by high source impedance due to their non-linear input capacitance. This point was discussed in the original B1 thread. The effect can apparently be heard, and certainly measured. So a low value pot, of say, 25K or less is preferred.
Anyway, this leads a logical approach, to me at least, where one may wish to have a line stage with high input impedance R to ground (say 250k), then buffer (b1 type) driving a lowish value volume pot (10 to 25k), which is then followed by either another jfet buffer (b1) or jfet gain stage / buffer.
If one use low gain, and low noise parts (BF862) in the gain stage, noise should not be an issue.
As mentioned, there are many ways to do this. Unless one assigns real world values for components involved, the "do's" and "don'ts" really have little meaning, at least to me. Everything is relative.
Bob
Old 9th June 2010, 06:14 PM   #229
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
BF862 Preamp
cascoded jfet stage is good for all these issues
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th June 2010, 07:07 PM   #230
R.I.P.
BNFY,
are you aware of the stray capacitances in your system and what effect they could have when they interact with your source and load resistances/impedances?
regards Andrew T.
BF862 PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
