BF862 Preamp
BF862 Preamp
Old 24th June 2009, 01:51 AM   #11
psgr is offline psgr  United States
How does it compare to J310 version that you posted in the Jfet Boz section?
Old 24th June 2009, 05:47 AM   #12
EUVL is offline EUVL  Europe
Take my word. Solder the JFET directly on your PCB without adaptor. And come back and tell us the difference.
Patrick
PS One way to match without adaptor :
http://www.diyaudio.com/forums/showt...32#post1828332
Old 24th June 2009, 07:34 AM   #13
juma is offline juma  Germany
juma's Avatar
J310 has its' charms, but BF862 is a significantly better choice here.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 24th June 2009, 02:41 PM   #14
juma's Avatar
Originally posted by EUVL
Take my word. Solder the JFET directly on your PCB without adaptor. And come back and tell us the difference...
Curiosity got better of me so I gave it a try, with and without grid stopper and there was no difference worth mentioning (compared to JFET on adapter PCB).
The only thing I noticed is a slight change of Id - due to a larger cooling surface I suppose...
What's your experience?
Old 24th June 2009, 04:00 PM   #15
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The J310 reqires some serious selection for noise. I have heard that FET's from this series, J305 on, are used in very low noise applications by some. In general I'd keep a small gate stopper on the BF862 since it has a 700MHz FOM, someone here was successful with SMT ferrite beads to preserve ultra-low noise.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th June 2009, 05:29 PM   #16
juma's Avatar
It's good to know that for MC/MM/mic preamps - we are talking line level (CD/DAC out) here so noise level is not a primary concern
Old 24th June 2009, 10:51 PM   #17
sandyhooker is offline sandyhooker  United States
sandyhooker's Avatar
This is how adapter PCbs look prior to soldering an cutting (DIL8 OpAmp is in pic for size comparison) :
I dreamt last nite that a copy of those boards appeared under my pillow!!!?? Did you make them??
Old 24th June 2009, 11:33 PM   #18
juma's Avatar
It must have made quite an impression on you
I'm responsible just for design of this simple micro-PCB, but the heavy burden of actually producing them fell on my friend's and DIY fellow's shoulders - he is the one with means and the will to manufacture such a miniscule PCB
Old 25th June 2009, 04:34 AM   #19
Doomed to be a friendless dreamer....
Old 25th June 2009, 07:27 AM   #20
juma's Avatar
NowI'm under impression that you would like to have some of these PCBs.
If so, PM me.
BF862 PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 10:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 11:13 PM
