F5 bias question
F5 bias question
Old 4th March 2013, 08:08 AM   #11
Marra is offline Marra  United Kingdom
F5 bias question
Don't just turn one pot you need to adjust them alternately by half a turn whilst monitoring the output and the voltage across R11 or R12.They interact a lot turning one alters the voltage over both resistors.
Old 4th March 2013, 12:49 PM   #12
rade95 is offline rade95  United States
Thats not the problem, I can go as slow as 1/2 turn each on P1 then P2, makes no difference. Something is bad, either P ch JFET or N ch MOSFET, I think.
UGS pre, stock F5, PassLabs X2.5, Aleph P
Old 4th March 2013, 12:57 PM   #13
cviller is offline cviller  Canada
cviller's Avatar
Marre could still be right - depending on where your trimpot is on its scale, there can be a lot of turns without any noticable effect. Best is to nul both and try again. Alternatively, you can take some good pictures and post them - someone might be able to spot something.
If you really want help, you can print out the schematics, place your ground probe on ground and measure voltage around the bias areas, write it on the schem, scan it and share it here on the forum. Then all the smart guys here will be able to help you quickly.
F5 bias questionHide this!Advertise here!
CCS bias question alexmoose Tubes / Valves 4 22nd July 2006 05:21 PM
Bias pot question Burnedfingers Tubes / Valves 1 1st January 2006 02:49 PM
A question of bias... DrG Tubes / Valves 30 28th August 2003 09:30 AM
a75 bias question SteveG Pass Labs 3 16th January 2002 11:06 PM
