Aleph J-X Amp Project - Page 141 - diyAudio
Old 19th March 2013, 07:20 PM   #1401
kroyin is offline kroyin  India
I tried increasing r4 on both halves from 221k to 2x221k did not work.
Worth decreasing R1 to 10k ?
Asus Netbook (ALSA+MPD)->EBay 4xWM8741 DAC->DIY DCB1 preamp with Optical Volume Control ->DIY F5T V2-> DIY 2.5 way Peerless Nomex by Troels Gravesen
Old 19th March 2013, 07:52 PM   #1402
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
it must work , even if I wouldn't go to double value
you didn't make something right
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th March 2013, 10:37 AM   #1403
In my understanding (perhaps flawed ) gain is set by a combination of feedback resistor,input resistor & resistor to ground.I rechecked their values and they are proper.
Increasing feedback resistor,decreasing input resistor (whatever I do) gives me additional 1VAC gain.
I must have done something wrong. Any other parts of the circuit that affects gain
Old 20th March 2013, 10:43 AM   #1404
Zen Mod's Avatar
ref. to original Pa's circuit , ratio of R4/R1 is defining CLG of amp
that's 221K/22K1
you can freely ignore R2 (221K) from that
Old 20th March 2013, 05:24 PM   #1405
Problem resolved...
I had explicitly grounded the daughter board to PSU.
I was trying out ARTA & it gave me a THD of 0.48% at 2.8V.
Generally I was unhappy
As part of fiddling process the ground wire came loose & to my surprise the THD dropped to .038%.
Whipped out my multimeter
Relative DC 12mV
Absolute DC -130mV
Gain 20dB
ARCHIMEDES MOMENT
Arta measurements attached
Old 15th July 2015, 05:29 PM   #1406
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Hi Everyone,
I'd like to build the AX-J, and have Peter's boards. Is it possible to build with the following specs and parts. I have used the A-X v2 spread sheet, but would like to ask the experts if I'm doing something wrong.
Transformers are 14.25v secondary volts at 267VA. Basically building around these transformers because I have several. They are Amveco toroids and look well made. 130C, potted centers and thermal protection.
From spreadsheet:
Rectified voltage is ~20VDC
19v at mosfets. .55A per mosfets.
8 mosfets per channel.
8 ohm is 24W output.
Spread sheet says Factor 3 is 251W. Factor 1 is 167W. Not sure what "factor" means.
Dissipation per channel 84W
Dissipation stereo 167W
Is the 20 volts provided too low?
I'd be willing to lower the current through the mosfets, if it helps.
Thanks,
Vince
I build, therefore I am.
Old 16th July 2015, 03:53 AM   #1407
koja is offline koja  Canada
wow, I was not aware of any of Peter's boards still being around. I gave up the idea of converting my PD Aleph30 to AJ and started planning on building F4s instead w/ a tbd preamp (probably BA-3 FE). still, if I had AJ boards I might be tempted to try a quick conversion over the same footprint on the heatsinks.
Old 16th July 2015, 05:40 AM   #1408
vdi_nenna's Avatar
I've had the l boards for years among others.
aleph 30 project traw Pass Labs 24 15th June 2012 06:47 AM
X Aleph Project Down Under macka Pass Labs 111 30th June 2008 02:55 PM
Aleph 2 project Thago Pass Labs 2 21st April 2007 08:44 AM
My aleph 2 project Jean Pass Labs 13 21st January 2004 08:14 AM
Aleph 2 (& others) as a project GRollins Pass Labs 41 11th February 2002 01:05 AM
Copyright 1999-2017 diyAudio
