Aleph J-X Amp Project - Page 134 - diyAudio
Old 2nd May 2012, 08:30 PM   #1331
Originally Posted by SCAIFF001 View Post
Sorry I have not been looking here for a few weeks. The heatsinks I am useing are two for each mono Aleph J-X, each of the two with a value of 0.33 degC/W, these also have one 5in. fan each attached to the each heatsink, the two heatsink fans are fed by two additional 5inch fans cooling the power supply components by having the two fans mounted inside the enclosures first & second barrier and the air is sucked by the first chaimber power supply components, these fans then blow the air through the three next air tight compartments and finally becomeing the source air for the power transistor heatsinks quietly keeping the output transistors with a tempiture of below 60degree Celcius while using a high bias.
here is the heatsink I am useing:
D180-20 - AAVID THERMALLOY - HEAT SINK, T SLOTS | Newark/element14 Canada
Thank You For Your Interest
Ian
Better (very) late than never...
Thank you!
Old 3rd May 2012, 07:24 PM   #1332
mace_be is offline mace_be  Belgium
Hello,
I am kinda new here. (Going to build an AJX 100 or 80)
Maybe an heatsink shop in europe tip:
Any one tried ordering the heatsinks only in the spare part section of the shop that sells hifi-2000 cases in italy ?
modushop.biz
In a few months i am going to try to order the spare parts only.
30 Euro's looks like a great price for an 300 X 40 H 210 mm HS.
But i am afraid they won't let you buy it seperatly.
I have also a question concerning PSU designer :
Where do you guys get the Transformer source resistance value ?
I looked at datasheets of toroids but dont find it.
- Is the impedance of the secondary wire ?
- You can just calculated it via the law of Ohm ?
I.E R = 18volts/22ampere (800va 2x18v toroid)
Best regards,
Jannick
Old 6th May 2012, 07:29 AM   #1333
SCAIFF001's Avatar
Default mounting front end board
When I look at the front end board it seams to me that the GND & SG are connected, is this true ?
Thank You
Ian
Old 6th May 2012, 07:54 AM   #1334
qusp is offline qusp  Australia
qusp's Avatar
use a multimeter....
Old 16th May 2012, 11:55 PM   #1335
pinnocchio's Avatar
Can anyone post the BOM on the first post of this thread? It would be appreciated.
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 24th May 2012, 01:21 PM   #1336
SCAIFF001's Avatar
Default speaker Xover with ballanced amplifier
Hi Everyone,
I was just thinking that since the output of a ballanced amplifier is just the same signal for positive & negative 180degrees out of phase then the xover must have the same filter components on its positive and negative speaker cables ? I was thinking of this because I am now assembleing my Aleph J-X input Line Level Crossover of 12db per octive at 100Hz, and here I must treat the positive and negitive Line Level Inputs with the same filter components, inother words two seporate xovers, one for positive Line and one for the negative Line.
Thanks For Any Help With This Issue So I Dont Blow My Speakers
Ian
Old 24th May 2012, 01:32 PM   #1337
Banned
I think this is a non-issue.
But you raise an interesting question.
Old 24th May 2012, 01:37 PM   #1338
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
that's not a question ;
at least not if considering type of amplifier output stage
AC is AC
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th May 2012, 02:19 PM   #1339
Do
Old 24th May 2012, 02:39 PM   #1340
Banned
Hi Everyone,
Ian
You bastard.
This is doing my head in.
If the positive phase of the signal is split through the passive crossover network, but the negative phase is not, resulting in the full frequency response of the negative phase across all woofers, then ...............
I am sure it must be a non-issue, but this is giving me a headache
aleph 30 project traw Pass Labs 24 15th June 2012 06:47 AM
X Aleph Project Down Under macka Pass Labs 111 30th June 2008 02:55 PM
Aleph 2 project Thago Pass Labs 2 21st April 2007 08:44 AM
My aleph 2 project Jean Pass Labs 13 21st January 2004 08:14 AM
Aleph 2 (& others) as a project GRollins Pass Labs 41 11th February 2002 01:05 AM
Copyright 1999-2017 diyAudio
