Aleph J-X Amp Project
Old 26th August 2009, 12:02 AM   #261
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Aleph J-X Amp Project Send a message via AIM to Peter Daniel
Originally Posted by algg View Post
how should the 2sj74's be soldered to the board?
Check this post and the attached pic: http://www.diyaudio.com/forums/showp...1&postcount=85
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th August 2009, 06:32 AM   #262
korben69 is offline korben69  France
Originally Posted by Peter Daniel View Post
Thanks Peter, I've missed this point.
Old 27th August 2009, 08:22 AM   #263
samoloko is offline samoloko  Bulgaria
Originally Posted by Bill Fuss View Post
With 1.8A bias per side about 180 watts per ch.
do you think that 2 per channel of SK56/200SA http://www.fischerelektronik.de/fisc...l_pdf/A_42.pdf will do the job
I would like to mount them 2 on each side of the stereo box
Old 27th August 2009, 04:18 PM   #264
Bill Fuss is offline Bill Fuss  United States
RIP
I would use the SK157/ 150, two per ch.
Old 27th August 2009, 06:50 PM   #265
I tested a single Aleph J channel today and everything works fine.
300VA, 2 x 18V Plitron transformer produces approx 28V unloaded and 26V after connecting to the amp.
Loosely matched SJ74 give approX 35mV offset.
Next thing will be J-X setup.
www.audiosector.com
Old 28th August 2009, 05:27 AM   #266
I wasn't actually correct, the DC offset was approx 2mV, I forgot about the offset produced by the generator.
The amp runs hot: the 8x8 heatsink with 1.75 fins was way too small for 2 x 18V transformer.
For AJ-X configuration, front end components (inside white border) should not be installed. I just removed them from test channel and I'm slowly getting ready for an X
www.audiosector.com
Old 28th August 2009, 12:19 PM   #267
algg is offline algg  United States
Default Resistor location on board
Hi Peter, thanks for the picture - very helpful! One more quick question. Why is R7 offset on your board - you soldered one leg to a different, unmarked thru-hole? Thanks!
-Alex
Old 28th August 2009, 01:20 PM   #268
The R7 footprint allows two resistor sizes: 500mil and 200mil, depending on the type used.
www.audiosector.com
Old 28th August 2009, 06:26 PM   #269
tms0425 is offline tms0425  United States
Peter,
What is the size of the thru holes you use for signal, ground, and power wires?
I am thinking of getting some turret terminals to facilitate quick solder/desolder for experimenting on mine.
Thanks,
Tom
Old 28th August 2009, 07:01 PM   #270
Those are approx 1.5mm (0.060")
www.audiosector.com
Aleph J-X Amp ProjectHide this!Advertise here!
aleph 30 project traw Pass Labs 24 15th June 2012 05:47 AM
X Aleph Project Down Under macka Pass Labs 111 30th June 2008 01:55 PM
Aleph 2 project Thago Pass Labs 2 21st April 2007 07:44 AM
My aleph 2 project Jean Pass Labs 13 21st January 2004 07:14 AM
Aleph 2 (& others) as a project GRollins Pass Labs 41 11th February 2002 12:05 AM
