Aleph J-X Amp Project
Old 14th January 2012, 10:30 PM   #1281
cka3o4nuk is offline cka3o4nuk  Ukraine
Send a message via ICQ to cka3o4nuk
Hello dear comunity
can anybody point to the right shematic of Aleph J-X Amp?
cant find it on the thread
Old 17th January 2012, 12:40 AM   #1282
derwhalfisch is offline derwhalfisch  New Zealand
You need to refer to the manual for the Aleph-J. The amp is just two J's with their front ends replaced by a common circuit posted a few days ago by Peter Daniel. If you compare the schem of Aleph-J with the X frontend you'll be able to find the overlap.
Here is the Aleph-J.
Old 18th January 2012, 10:05 AM   #1283
SCAIFF001 is offline SCAIFF001  Canada
SCAIFF001's Avatar
Default populating the front end pcb
Hi everyone,
Is it just me or is populating the front end pcb is difficult to souder, the souder is not attaching itself to the pcb very well for some reason, is there anything I should do about this ?
Thank You
Ian
Old 18th January 2012, 10:28 AM   #1284
qusp is offline qusp  Australia
qusp's Avatar
I had no problems, nothing different to any average PCB, the traces are not particularly thick, there is no ground plane to suck out the heat.
try some flux and perhaps higher heat. i dont know what else to recommend because if its not working normally there is something else at play other than the pcb.
are you using quad eutectic or lead free solder? what tip? although any standard tip should be fine
Old 19th January 2012, 05:47 AM   #1285
h_a is offline h_a  Europe
h_a's Avatar
You definitely should do something about this as you risc cold solder joints otherwise. Besides the poor contact itself, it leads to crackling noises.
Use more heat! Hannes
High Octane phono preamp Wiki
Old 21st January 2012, 11:34 AM   #1286
SCAIFF001's Avatar
Default clean souder iron point
Originally Posted by SCAIFF001 View Post
Hi everyone,
Thank You
Ian
I have been keeping the soulder iron point clean, or at least I thought it was, I have sanded the tip with sand paper and the iron works great now, I never knew that I had to do this sanding of the tip, and will redo all of my saulder iron connections when this problem surfaced.
Thank You
Ian
Old 21st January 2012, 11:41 AM   #1287
SCAIFF001's Avatar
Default mounting P1
I am at my last item of populating the pcb(s), mounting "P1". On the pcb there is a little circle with a line through it at one end of the white mounting rectangle with three holes in it. Dose the screw for the pentiometer mount at this end, or dose it not make any differance ?
Thank You
Ian
Old 21st January 2012, 12:47 PM   #1288
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Aleph J-X Amp Project Send a message via AIM to Peter Daniel
It doesn't make any difference.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st January 2012, 01:40 PM   #1289
qusp's Avatar
sanding the tip will eventually lead to it failing quicker than if you just keep it properly and regularly clean with brass wool
Old 21st January 2012, 01:43 PM   #1290
Just to remind, that functional amplifier and some additional info were presented here: http://www.diyaudio.com/forums/pass-...ml#post2012118
www.audiosector.com
Aleph J-X Amp ProjectHide this!Advertise here!
aleph 30 project traw Pass Labs 24 15th June 2012 05:47 AM
X Aleph Project Down Under macka Pass Labs 111 30th June 2008 01:55 PM
Aleph 2 project Thago Pass Labs 2 21st April 2007 07:44 AM
My aleph 2 project Jean Pass Labs 13 21st January 2004 07:14 AM
Aleph 2 (& others) as a project GRollins Pass Labs 41 11th February 2002 12:05 AM
Copyright ©1999-2017 diyAudio
