#781 |
Upgraded the supply caps from elna for audio 4700uF/45V into Silmic II 3300uF/50V. My transformator out is 15-CT-15.
Will it goes significant better when using 4700uF instead 3300uF? Is it a good idea to paralleling the caps using MKP or oil caps with small value (under 1uF)? I am using 1N5819 diode, Is it okay paralleling each diode with 1nF to make into a soft recovery diode? Thanks
#782 |
or will It goes even better with 6800 or 10000 uF
I am thinking of buying 6800 /35 Panasonic TS-HA for a similar project - what do you think about that cap |
#783 | |
diyAudio Chief Moderator
#784 |
#785 |
#786 |
Banned
#787 |
#788 |
Is it safe changing: * 34R 1W into 10R 1W * 220R into 1K Thanks |
#789 |
which schematic are you referring to?
#790 |
The shunt regulated, posting #10-12 schematic.
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
