Old 6th December 2009, 06:28 AM   #671
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I'm going to buy a nice alps
Old 6th December 2009, 08:57 AM   #672
JeroenR is offline JeroenR  Netherlands
Originally Posted by woodturner-fran View Post
Cases are the bane of every diyers life. I gave up ages ago trying to make my own and now always re-purpose a chassis from something else. My current one for the dcb1 is a broken cd player. Key problem is the very high cost of nice chassis and I don't ever see them getting cheaper.
Fran
For Europe this seems a good alternative : Hi-Fi 2000 contenitori per l'elettronica, case modding HTPC, Galaxy, rack, DIYaudio, computer cases, knobs,milled Handles, milled fronts, hi-end,
There are a lot of sizes and they seem not too expensive, approx EUR50 including shipping.
edit : EUR50 based on a 23x17cm case for the B1.
Old 6th December 2009, 10:11 AM   #673
Originally Posted by Salas View Post
1. Don't know specifics about your transformer ratio and reflected impedance needs of your circuit. Very general a question.
2. Nothing smothers pot subtleties in a DC super low parts count circuit like this one if you are about to investigate pot qualities. There is not that much between cheap carbon and better conductive plastic beyond the obvious mechanical quality and longevity gains, a cheap switched is a very good value, but ultimately look to make a Lightspeed.
Salas,
the traffo ratio is 500:500, Freq responds is 10-50K....I think it's a utc a-20 if not mistaken......hope this info could give you some clue.
Old 6th December 2009, 11:25 AM   #674
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
1:1 then. 20-25k pot will do.
Old 6th December 2009, 12:04 PM   #675
thank you very much....but what should it be if i use output transformer (1:1) then a tube output...?? is 50K as mention on the DC Coupled B1 Shunt PSU V4.3.pdf ?
Old 6th December 2009, 12:41 PM   #676
Salas's Avatar
If you feel like employing in your additional tube circuit after the transformer some smallish output capacitor (no less than 2.2uF), then you can use 50k pot and change the 220k input to ground resistors on DCB1S to 560-680k.
Old 6th December 2009, 12:54 PM   #677
note that...thanks salas
Old 7th December 2009, 01:21 PM   #678
massimo is offline massimo  Italy
I'm working on it. If you chose the 28 cm deep version, you could also fit a suitable xfrm.
My idea is to hold the pcb (Hyp or Mez) with some 3 x 3 cm L shaped alu bars 5 cm apart from the back panel. The bars will also provide heatsink for the mosfets and hold the selector sw and volume pot for Hyp board.
The xfrm (Hammond 229D24) will be placed close to the front panel with other 1,5 x 1,5 alu bars.
Stay tuned
Old 7th December 2009, 01:32 PM   #679
udailey is offline udailey  United States
Passive Aggressive
Massimo,
I am not sure about this but if I am right you will short a turn on the transformer by mounting it to the chassi with an aluminum bar on each side if you will be attaching it by the core that sticks out the sides of that transformer. I would mount the transformer on some perf board or similar then mount the board to the chassis. I could be wrong about shorting the turn. But thought I should warn just in case.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 7th December 2009, 01:42 PM   #680
The Hammond 229 series are PCB mounting xfrm. Thus a pcb (or two small pieces of prefboard) will be used to hold the xfrm and it(they) will be bolted to the alu bars.
Wait and see....
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Page generated in 0.15705 seconds (72.25% PHP - 27.75% MySQL) with 11 queries
