#601 | |
There's a string of 3 and 5 leds - where does this apply? Thanks, JG |
#602 |
Passive Aggressive
Hey JG,
Dont use 2 fuses. Put one on the primary. You dont want one of your two fuses on your secondary frying and the other surviving. Sacrifice the fuses Put only one on the primary.Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#603 |
Ok, I'll use 1 fuse. There are 2 fuses on the BOM & 2 on the schematic.
I just was a bit confused as to why. |
#604 |
diyAudio Chief Moderator
#605 |
Merlin, 1 fuse is specc'd for 230V mains and the other for (US) 110V mains.
Fran |
#606 |
I added in the new transformer last night, 15V secondaries. So it powers up fine and I get basically the same voltages out of the shunt. So all is well. The other thing I did was do a bit of fiddling with the 68R//68R. I followed AndrewTs advice and started by adding a 3rd 68R in parallel to drop the resistance in stages. Anyway, right now I have 68R//68R//10R in parallel (just didn't want to take out the 2 68R yet until I was sure there was no heat issues). So anyways, I haven;t really got to listen yet, but the 140/9140 still barely get warm, I'd guess 30degC, no more (I'm used to the F5 !!). So next step now is to swap them out for the 10R on its own.
BTW, I also did the mod using the coax instead of the regular silver in teflon and it made absolutely no difference at all. I was really surprised that there wasn't some change! I know the runs are short (about 50mm-80mm), but I expected something!! So the plan tonight is to listen, swap the shunt resistors, listen, and then maybe put in the lightspeed if time allows. Fran |
#607 |
Measure the resistance of the combination you got right now for Rset and the voltage across so we know you really got high current. 30c sounds fishy. No difference with coax, means you had no real noise picked up by the open weave. Checked.
P.S. The regs outputs are supposed not to change, its just that sufficient input margin lets them perform as intended. |
#608 |
#609 |
For having a spare I guess.
#610 |
I got 100x 2sk170BL in from China the other day. I wont be needing them all. (Unless I can think of something else to build.) I initially placed an order with Mouser - but they were on backorder for months. So, if anyone wants 50 pieces email me. I'll set the price to 1/2 of what I paid for them. $20 USD (free shipping too.) Thanks, JG |
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 01:14 AM |
