| Thread Tools | Search this Thread |
#571 | |
Here are details on the shunt mod that i did. Shunt Pot Volume Control - World-Designs-Forum It does sound good, but im not sure if it is suited to the b1 application. I guess the only way of knowing would be to swap it out for a 20k pot and have a listen. Then again maybe i should just get a DCB1 Board and build that. Are there any DCB1 boards available? I like the idea of a capacitorless b1...my power amp is a wad kat34 and im sure it has 1uf input caps. Here is the schematic to the integrated version, the Kit34. http://www.simpletube.com/databank/P...F80_inte_2.pdf Do you think the DCB1 could be used with the Kat34? Thanks for your Help. Alon |
#572 |
so, just one more update on my build. I upgraded to a 25k stepped attenuator and takkman resistors. I ended up with one pair of cardas and 5 sets of connex input RCA's and Cardas for the output RCA's. Wiring was all done with yada yada wire. I am quite happy. The sound is first class. Beats the heck out of anything else I have around. I plan to tote it around to friends houses and try and get some comparisons when time allows. One small issue I am having is simply that the first step of the attenuator is too loud for my wife's taste. What would be the simplest method for dropping the output by a few db's and not screwing up the whole balance of things?
#573 |
Passive Aggressive
Dave,
Since the shunt resistor is of very low ohms in that position you will change the volume but not the 'whole balance of things' by swapping in a lower value resistor for the low volume shunt resistor. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#574 |
hi.do you know somewhere that i can find high quality 20k alps pot or as quality as alps? I have RK27 motorized 50k pot but I heard that 50k is not suitable for B1 buffer.is it true ? thanks
#575 | |
diyAudio Chief Moderator
DCB1S is quite nice for the 34 kit you linked. Just delete its 100k input pot, no use. |
#576 | |
#577 |
20k I recommend on transparency grounds. It suits the DCB1 better. There is no technical reason that a 50k pot will not work on the other hand. I repeat, you must up the across input 220k resistors to 560k or 680k if to use a 50k pot. As for Alps or alike vendors, Google is your friend.
#578 |
I do not have much money and i want to have good quality buffer. I think I will use 50k alps RK27 pot.Thank you
#579 |
Doh! That is obvious. I should know better. Thanks for reminding me of the obvious.
#580 |
Hmm.. I'm about to place an order @ Partsconnexion.
Takman or PRP ? |
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 02:14 AM |
| Page generated in 0.13240 seconds (79.28% PHP - 20.72% MySQL) with 11 queries |
