Building a symmetrical psu B1 buffer - Page 51 - diyAudio
Old 22nd November 2009, 06:41 PM   #501
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by Salas View Post
I would put the stronger one lower between a close enough match. Like 0.2mA dif. Not like a 6 with a 7 or an 8 with a 9 etc.
So the lower one has a bit higher Idss just as I understood earlier ?
I changed them today for 8,08 mA upper and 8,15 mA for the lower FETs. Result: - 3.8 mV and - 4,2 mV offset. This was still without matching the LEDs.
It's only audio. Member of the non modular PCB design committee
Old 22nd November 2009, 08:05 PM   #502
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Thats an excellent result for the fast approach. I have mentioned some ''esoteric measures'' that I have inbuilt towards it being a DC coupled but forgiving enough DIY. Did you apply it in your sound system yet?
Old 22nd November 2009, 08:27 PM   #503
jean-paul's Avatar
I only tested the prototype and I was quite satisfied with it although it was not far from breadboard status. The two I am working on are finished ( and built with better parts ) except that I am waiting for the cables that a friend will crimp for me. Been away last week so as usual it delayed. Count that delay with the lack of time because of work and you'll know the story.
One of them will play within a week or 2 I guess. Encased that is ! I bought a stepped drill a while ago so drilling the holes for the RCA connectors won't be a problem this time.
BTW are the values for the LED strings really that critical ? I have 5,78 over the 3 LEDs and 9,4 V over the 5 LEDs. All yellow LEDs.
And what about bypassing the 100 uF caps ? I am surprised no one has mentioned it (yet ). Or do you think that is not necessary ?
Old 22nd November 2009, 09:32 PM   #504
Salas's Avatar
The +/- 10Vout target area which is reached in accordance to mostly Vf and vref's running current is a subjective ''sweet spot'' as I have found with 7-8mA BL. Back in the B1 thread when I was testing voltages on the fresh prototype with series regs, Nelson Pass had augmented my notion by an agreeing post about better areas actually existing for Jfets, saying that he even got some data if you remember. See to have about 0.2-0.5V positive diff slight asymmetry for +/- 9.5 to 11V Out. Also less than 5mV DC offset is more than good. So if you are in that ballpark is OK. Enough matched but not that hard matched will do. You got snug very nicely where I targeted it, that shows that your Leds are well chosen from datasheet and near tolerance. Yours is OK. No further action needed.
Don't bypass the 100uF caps as a given upgrade IMHO. Everytime an electrolytic is bypassed as such with 0.1uF etc. I can perceive hardness. Maybe you know some nicely working combination of types and makes from other applications, then only try. In general I prefer a straight Silmic II, Pana FM, Nichicon FW, Elna BG, from some small compact cap bypass. Maybe an RC Zobel with a small R and 1uF film could do better than a straight film bypass. Tip: The more sensitive to subjective alterations position, is the 5 Leds bypass position. But I leave such play with 100uF makes and bypasses to you guys, so to enrich the thread.
Also, if prepared to really sink the thing either on thick enough metal enclosure floor or on big enough sink by mounting the Mosfets like in power amps, underneath with bent legs, you can lower the current set resistors combination value to 10R 5W each side and cruise the regs around 200mA. That, you will hear.
Old 22nd November 2009, 10:46 PM   #505
Well, I powered mine up tonight!! She lights up like a christmas tree and all seem well.
I get 10.1V and 9.6V at the output of the shunt - on an exceptionally low line voltage tonight of 220V. Tx were putting out 10.6 and 11.2VAC - normally this is a little above 12VAC (this could be why the neg reg has a slightly lower output).
The muting relay clicks in after about 5secs. The other relays all work AOK, tested by shorting the input pins to gnd.
Salas - the 270R for the V-drop for the 6V relays worked AOK,they are being fed 6.2V. I have a clip-on heatsink on the 7812 but its cool - could get away without one handy enough I'd say.
No buzzing or anything with the BC550 instead of the BC517.
2 separate transformers seem to work AOK.
DC on the outputs: 0.3mV and 1.3mV after being on for ~30mins
IRFP140/9140 barely get warm sitting on the bench (admittedly fairly cold out in the workshop tonight.
Thats all I can think of right now. My chassis is coming on well, but I have yet to make the lightspeed attenuator for it. I plan on just shorting the pot to start with just to test out first....
Fran
PS. Salas, that mention of 5W 10R - a single one of these to replace the paralleled 68R? Mine will sinked on a large 3mm alu plate....
Old 23rd November 2009, 12:16 AM   #506
Salas's Avatar
Your Tx secondaries are below spec when you have low mains. You need to measure the DC voltages on the main filter caps and the voltage drops across the 3 Led strings & 68R//68R and let me know.
Yes a single 10R 5W will do so to run the shunts high if you fancy. But run the system in using some normal pot so to get acommodated with its sound before you will either up the CCS current and/or add the LSPD, so to appreciate and communicate your impressions better.
Old 23rd November 2009, 09:56 AM   #507
OK. I have an ebay stepped pot that I might stick in just for now. Its a 50k but at least I'll get a handle on the sound. I had that in the "normal" B1 first and noticed how I got more clarity when I moved to the LS there. It would be good I suppose to follow that same methodology here.
Fran
Oh yeah, I'll do the measurements you suggest later tonight....
Old 23rd November 2009, 06:15 PM   #508
Measurements:
V at filter caps: 13.8 and 13.8V
Drop across the 3 LEDs: 5.45 and 5.49V
Drop across the //68R: 1.789 and 2.150
Line is low again tonight at 219VAC. Every other time I have ever measured it, its been >230V. Maybe I would be better with a transformer with 15V secondaries?
Fran
Old 23rd November 2009, 08:22 PM   #509
jean-paul's Avatar
Thanks for all the time and answers. I won't sink more current as I am very ( too ?) conservative with useless heat and waste power. IMO when people would be somewhat more conscious about energy we would not have the problems we have today in this world. It all starts with small things ...
Old 23rd November 2009, 09:18 PM   #510
Salas's Avatar
Originally Posted by woodturner-fran View Post
Measurements:
Fran
52 & 63mA running current. I would like to see 16-17V on the caps so the CCS could reject wider ripple amplitudes as a margin, but I doubt you get any more than in 100-200mV range. If when you listen to it, you still can't perceive any roughness, then you should be OK. Else, you should up the secondary specs with the mains low plateaus you experience.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright 1999-2017 diyAudio
