| Thread Tools | Search this Thread |
#461 |
My sounds great from the word go. how did the soncis change?
I have come from pedja rogic buffers, which were quite dependant on the otuput cap. |
#462 | ||
diyAudio Chief Moderator
It is true, it will sound looser after some initial play. Its the electrolytics in the shunts mainly needing to flex a bit. Big relief sans cap, and a money saver too. I know. Nice system BTW. I especially like Baby Huey as a concept. Regards |
#463 |
Hi, I've got a quick question.
Looking at bom v4.2 there are 5x 100uf caps needed. I see the spots for them on the board. I'm wondering where decoupling cap B (which is supposed to be near c517) where does that go? It's 150nf/63v film cap. Thanks, JG |
#464 |
not politcally affiliated
right near the 7812 regulator, says 100n.
SemiSouth R085/R100A JFET available now DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE |
#465 | |
Decoupling A and B: these two caps can be any MKT or Mylar from 100 nF to 220 nf, whatever you have handy. The "A" cup has been "forgotten" drawing the pcb and must be soldered under the board. Turn the pcb and see the cap "B" (100 nF on silkscreen) pads: one is connected to the center pin of the LM7812, the other to the pin close to the center of the board. The "A" caps goes to the center pin of the regulator and the other pin, close to the pcb edge. |
#466 |
No. The 150nF is in the BOM, only if the peculiar ''relay chatter'' phenomenon ever occurs again, just for being ready. With BC517 is highly unlike to occur. So if no BC517 is available, but say a BC550 is, and some relay types or makes prove to buzz mechanically, you strap the 150nF cap underneath board between collector and base of the lower BC550 that pulls the relay coil's current. The 100nF has a board position right next to the 7812 and it is for decoupling that reg's input since there is some inductance on the rather long pcb foil that gives it the juice from the main filter's tap off for it.
#467 |
IMO one small cap at the o/p of the regulator is always a good practice, anyway. At least it won't hurt.
#468 |
If the 150nF proves non needed for chatter, nothing is needed there. Its not an audio circuit so to decouple better the 7812's output for better treble for instance. With the relay drive there are two possibilities. 1. Clicks, releases normally. 2. Buzzes. The second possibility is remote if using BC517. We just had some weird buzz with some relays in the proto builds in two cases. That was with simple npn driver, not Darlington like BC517 is. Just because the other guys with same configs did not mysteriously get it, we included the cure if with simple npn drive. Namely the 150nF cap, so to be there if something arises or BC517 isn't available to someone. Yet if it ends up surplus to a build and no other use for it, you can strap it across 7812's out to ground underneath, no problem.
#469 |
Here's my board so far: I'm waiting on some 170's, and got to sort out my leds. 2 things: 2 jumpers are required on the board right? (1 extra if you use 12v relays) I've got decoupling cap b on board 100n right next to the 7812. So decoupling cap A is not needed? Thanks, JG Last edited by merlin2069er; 21st November 2009 at 12:41 AM. Reason: picture |
#470 |
Do you have BC517? Yes two white lines=two jumpers.
P.S. Your photo link isn't showing. |
| New-building of my B1 buffer | Babowana | Pass Labs | 328 | 20th February 2010 02:14 AM |
| Page generated in 0.11301 seconds (71.68% PHP - 28.32% MySQL) with 11 queries |
