Building a symmetrical psu B1 buffer
Old 19th August 2013, 02:44 PM   #2611
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Hi Udailey, thx...
I use permanent marker & hand drawing
it is my old way but you can try it, it's fun & work very well on me.
well I hope I can explain what I do correctly:
First I print the layout in a paper, than make a sandwich (paper on top the board)
with a little hammer hitting the steel needle I made a mark on the copper side, so dot's (a little hole made by the needle) everywhere on the copper plane. The little hole help a lot to guide you to drawing on the blank copper plane (also when drilling the pads make more accurate). Then I start to draw pads, all pads, all traces,... that quite exiting
Double or triple the layer with permanent marker for best result (I even add refill ink on new marker, they dried fast)
Error drawing, don't worry fix with it :
"the magic pencil"
http://imageshack.us/a/img850/549/tusukjarum.jpg
That why it is called PCB arts-work
ps: I'm sorry for this off topic
Thank you, I wish you happy
peace & G B U
Last edited by JOHN BALI; 19th August 2013 at 02:54 PM. Reason: it is a bit difficult to explain
Old 19th August 2013, 03:50 PM   #2612
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by JOHN BALI View Post
Hi, ...
this is my finished hand made PCB ... but it will be slowly build
Vintage cool diy with curved vias. Great.
Old 21st September 2013, 01:56 PM   #2613
JOHN BALI's Avatar
Default I guess it's ready to test
Originally Posted by Salas View Post
Good luck then. What kind of amplifier you project it to drive? Does it have at least 26dB of gain so a buffer will bring enough sound pressure level?
Hi Sir Salas,
sorry for very late reply, ...the amp is 30dB & another one 40dB...
Today I almost done it, I want to test the voltage first before put the missing 2SK170 pairs
because I can't get 1.8 volt LED's so I use 1.88 volt instead.
I hope nothing bad happening
peace & G B U
Old 21st September 2013, 02:15 PM   #2614
Salas's Avatar
Looks it turned out good. Don't worry about that small Vf extra in the LEDs. Its how they produce them now.
Old 22nd September 2013, 12:55 PM   #2615
JOHN BALI's Avatar
Default DCB1 is Ready to Rock
Hi all...
I measured the voltage today & they are okay I guess
so I put the 2SK170 pairs & they are a bit warm
Hey, they are working
maybe tomorrow I will surprise with the sound
Warm Regards
peace & G B U
Last edited by JOHN BALI; 22nd September 2013 at 12:58 PM. Reason: missing pictures
Old 22nd September 2013, 02:12 PM   #2616
Salas's Avatar
Fine until now. Verify that the relay clicks to engage the audio outputs. You should measure some DC offset at the audio outputs. If it is lower than 5mV it is acceptable.
Old 25th September 2013, 03:54 PM   #2617
JOHN BALI's Avatar
Default All Ok, thanks to all
It all fine...
The relay clicks after few seconds, I just use BC550C for relay(no BC517 available here locally).
DC offset is below 5mV, the DC offset was about -1mV to -2mV.
Thank's for Salas for this wonderful circuit...
& Nelson Pass for the B1.
If anyone want to try it too I will give the layout
or should I post it here?
peace & G B U
Old 25th September 2013, 04:17 PM   #2618
Salas's Avatar
Congratulations. Did you put it in your audio system too?
Old 25th September 2013, 07:05 PM   #2619
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
It all fine...
Please post your layout
RC
Old 26th September 2013, 03:23 PM   #2620
JOHN BALI's Avatar
Default I like it :)
Yes, I did it ...
When I use the amp with a bigger gain, the difference is not so much
(maybe amp was not built properly by me )
Then I use the PeeCeeBee ...
Now I could feel my work is more alive, what a surprise ...
If I said the amp is only 50W then they (some people here, nearby) will say I was lying because the sound is so loud.
Better bass, mid, & high,
when I use tone control in the amp,
I turn to max position(not the volume) & no "over control" like before.
The DCB1 make it straight like what it is should be
I like it so much, maybe I should make it again some day
Please note that I'm use cheap source that built in volume & remote control so I don't use 20k pot (but I already order it).
So next time I must use better setup & get ready for another better story
Hi, RCruz only if you want to build it fast
Ok, I will post it tommorow cos the PC I use is being repaired
there will be bottom & top component placement, jpg & pdf
peace & G B U
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2017 diyAudio
