Building a symmetrical psu B1 buffer
Old 28th February 2013, 10:06 AM   #2591
R.I.P.
Originally Posted by AndrewT View Post
The B1 has two switchable inputs. That's where the two sources connect.
Then the switches should feed the selected signal to the attenuator.
Finally the output of the attenuator is fed to the buffer since the attenuator cannot alone drive the cables to the power amplifier and/or the pre-amp..............
Originally Posted by ckwong99 View Post
...................My concern is the order arrangement for the shunt type attenuator and B1 buffer. You know the shunt type attenuator drawback is vary of impedance to its next stage. Base on my situation, how following option is better deployment ?
Option 1) Source signal -> Shunt type attenuator -> B1 buffer -> Tube Preamp...................
regards Andrew T.
Old 1st March 2013, 05:38 AM   #2592
ckwong99 is offline ckwong99  Hong Kong
Thank Andrew,
Do you know the optimal value of series resistor inside the shunt type attenuator ?
Now the kit come from 10K value installed but I think it is no assumption the user will apply a buffer behind it ....
Old 16th March 2013, 10:05 AM   #2593
westers151 is offline westers151  United Kingdom
Default Lowering the output impedance?
I've read that the output impedance of the DCB1 is 260 ohms. The amplifier this will be connected to prefers around 50 ohm output of the pre-amp, although 1K ohm can be supported.
How could I lower (or raise) the output impedance to match the values above?
Old 16th March 2013, 10:47 AM   #2594
R.I.P.
The output impedance is made up from a combination of the output resistor and the follower's output impedance.
You can change the output resistor for a lower value. But you must check that the adopted value does not allow the B1 to become unstable on fast changing signals/interference.
regards Andrew T.
Old 16th March 2013, 05:16 PM   #2595
Is R4 the correct output resistor to change? If so, would it be a correct assumption to calculate the follower's output impedance as 260 - R4?
R4 = 220ohm, therefore the follower's output impedance is 40ohm
Without a scope, or test equipment (apart from a DMM), how could I check to see if a lower value is causing it to be unstable?
Old 17th March 2013, 12:03 PM   #2596
R.I.P.
without a method for checking stability, stick with the 220r.
An Rs=260ohms is not bad (actually rather good) at driving a capacitive cable and reasonable Zin. Try 5m of 100pF cable into 20k Zin.
regards Andrew T.
Old 2nd August 2013, 02:33 AM   #2597
kiennat is offline kiennat
Originally Posted by Salas View Post
That layout is vintage of what later sprung to Mez and Hypno in their popular forms. Nice to see it done again and playing well. Watch turn off cycle mainly if to ever drive a DC coupled amp since there is no relay. Enjoy.
Salas, can you send me the EAGLE files ? I want to build it
Old 2nd August 2013, 05:35 AM   #2598
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I only had those print files I posted back then. You can find them in the first pages. That is the way he also did it in that link, graphical transfer.
Old 10th August 2013, 02:45 PM   #2599
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Default I want to etch this
Hi everyone,
I've read all post here from page 1 to last one... need some days
I want to use my own layout, please some comment before I go to etch it PCB
Maybe I miss something important...
Question:
Is that okay to use 2 + 3 LED's (bright one) instead of 3 + 5 LED's...?
(all I need is to match the voltage to 5.4v & 9v)
Thank you, I wish you happy
peace & G B U
Old 10th August 2013, 03:39 PM   #2600
Salas's Avatar
I wouldn't pretend that I have the energy to scrutinize your layout for connections (40C here). Just make sure it follows the schematics accurately.
But others may spot something or not.
Unfortunately super bright LEDS have a reputation for being noisier than normal ones which I can not confirm how much right now.
But surely I have never seen them in instrumentation as voltage references. Better use 3mm generic reds or greens in the 3+5 proven configuration.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
