Old 30th December 2012, 08:09 PM   #2581
Are you sure the electrolyts is mounted correct ?
Old 31st December 2012, 12:26 PM   #2582
ncc is offline ncc
Send a message via Yahoo to ncc
Yes, I've checked again and all electrolytics are mounted correctly
Old 5th February 2013, 11:56 PM   #2583
noSmoking's Avatar
hi ncc,
I checked google for bc517 and it's a high Hfe darlington,I am not sure bc550 will do it ,might try MPSW45A and 2N6426 are similar to BC517, both are good.Pinout is different.
NS
Old 6th February 2013, 12:26 AM   #2584
noSmoking's Avatar
Hi Salas,
My Mezmerize is working great ! It went right together and played fine ,Sounds Great!
THANKS!
NS
Old 6th February 2013, 01:24 AM   #2585
MPSA 13 ?
Old 6th February 2013, 03:16 AM   #2586
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sounds like a candidate. Should reverse its orientation and check that the 7812 is good.
Old 6th February 2013, 03:31 AM   #2587
Salas's Avatar
Originally Posted by noSmoking View Post
Hi Salas,
THANKS!
NS
That layout is vintage of what later sprung to Mez and Hypno in their popular forms. Nice to see it done again and playing well. Watch turn off cycle mainly if to ever drive a DC coupled amp since there is no relay. Enjoy.
Old 25th February 2013, 03:55 PM   #2588
Hello there,
These is my questions :
1) Can anyone know how to arrange my B1 buffer + Shunt type attenuator + tube pre-amp order for the best deliver the source from CD player or Phono ?
2) What is the optimal value of the signal in series resistor for the shunt attenuator with B1 buffer interpose ?
Thanks for your answer in advance
Old 26th February 2013, 09:50 AM   #2589
The B1 has two switchable inputs. That's where the two sources connect.
Then the switches should feed the selected signal to the attenuator.
Finally the output of the attenuator is fed to the buffer since the attenuator cannot alone drive the cables to the power amplifier and/or the pre-amp.
Do you really need a pre-amp?
Which signal needs more amplification?
Do that before you send the signal to the attenuator.
Old 28th February 2013, 05:04 AM   #2590
Hello Andrew,
Tube preamp was my DIY project finished in few years ago but last year I added B1 buffer on it. All the sound and presentation is slightly better than before. Right now I am replacing my Preamp's 24 steps attenuator by shunt type attenuator (with remote control and has 80 steps). Actually, I want the phono signal can get a better presentation.
My concern is the order arrangement for the shunt type attenuator and B1 buffer. You know the shunt type attenuator drawback is vary of impedance to its next stage. Base on my situation, how following option is better deployment ?
Option 1) Source signal -> Shunt type attenuator -> B1 buffer -> Tube Preamp
Option 2) Source signal -> B1 buffer -> Shunt type attenuator -> Tube Preamp
Another question is how to selection the value of series resistor inside the attenuator ?
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2013 diyAudio
