Building a symmetrical psu B1 buffer
Old 26th July 2012, 05:00 PM   #2561
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by KatieandDad View Post
I couldn't hear any difference with running the SALAS Shunt Reg at currents above 300mA. In the end I opted for 160mA (ish), the MOS-FETs run cool and there is no danger of component cooking.
Irrelevant of the current the PSU is consuming, the B1's run at about 7-10mA each (determined by the Idss of the 2SK170BLs).
The 2E heatsinks run at a nice cool 30 degrees at 200mA but start to heat up rapidly above 300mA.
You will notice that I opted to use the SALAS Reg Supply part of the DCB1 but then used the B1 itself. I needed the capacitive coupling so the combination of the two suited my application perfectly.
Old 26th July 2012, 05:17 PM   #2562
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Since I'll be running my setup in balanced mode, DC will not be an issue for me. But yeah, I agree with you, whatever suits your equipment need is what you should go for!
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 29th July 2012, 07:47 PM   #2563
juanitox is offline juanitox  France
juanitox's Avatar
is worth to have separates regulator for right and left rails on B1 ?
French is not a crime.
Old 29th July 2012, 07:53 PM   #2564
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Small subjective gain.
Old 4th August 2012, 10:27 PM   #2565
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
I do not understand 21 V into 10 ohm resistors and 10 V out from supply and I can not feel any temperature rise at all.
Old 4th August 2012, 11:04 PM   #2566
Salas's Avatar
That's very good sinking for 200mA or less. Have you got 1.6-2V voltage drop on the 10 Ohm resistors? If yes you surely run spec current. Maybe you can double up on them and drop them to 5 Ohm so to benefit from more current since you got nice dissipation bond to chassis.
Old 4th August 2012, 11:28 PM   #2567
Yes 1,6 V across 10 ohm. I will follow your advice and use 2 more 10 ohm resistor.
What abuot the 10 V output ? Short circuit one Led in each side ?
Old 4th August 2012, 11:37 PM   #2568
Salas's Avatar
Why? +/-10V is the spec.
Old 5th August 2012, 04:36 AM   #2569
Oki I thought 12 V .
Old 23rd August 2012, 10:45 AM   #2570
umut1001 is offline umut1001  Turkey
umut1001's Avatar
Hello.I build dc coupled b1 preamp very simple, without regulators and potentiometer.I used 12volts empty 23AE type batteries(they measure about 10,5volts when empty)I used 100uf 10v rubycon za capacitors,dale hi end military resistors on pcb(i heard that rubycon za is very similar to rubycon blackgate caps)Buffer sounds excellent!Thanks Salas and Nelson for B1 buffer.
I matched 1% drain current with 9v batteries.Drain current is about 9,09ma for all fets.
I want to connect a battery for it,because i like battery for sound.Clean DC.Can i use +-12 volts lead acid battery with series resistors?Or maybe 9v lead acid batteries?Thank you
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 02:14 AM
Copyright ©1999-2017 diyAudio
