Building a symmetrical psu B1 buffer
Old 10th February 2012, 10:46 AM   #2411
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I've just bought a batch of 2SK170BLs (16 of them) for Igs matching.
I am somewhat confused that six of them have Igs = 7mA (ish) and the remainder are 2mA (ish).
Is this normal ?
I can accurately match pairs with Igs around 2.22mA.
This is tested at 10V with G and S shorted.
Old 10th February 2012, 10:58 AM   #2412
R.I.P.
Idss is the current that passes when Vgs is zero (i.e. G & S shorted together) when Vds = 10V and Tj = 25degC.
A 9volt battery and room temperature is acceptable for first batching.
Use a 1r0 1% resistor as your current measuring device.
Apply 9V to 1r0+jFET
Measure the mV drop across the resistor. That is your approximate Idss.
regards Andrew T.
Old 10th February 2012, 11:15 AM   #2413
That's what I did, except that the 1R0 was the internal resistance of the meter on mA range.
I'll try again with 1R0 and measure as you have suggested.
Old 10th February 2012, 11:22 AM   #2414
The results are exactly the same..??
Old 10th February 2012, 11:31 AM   #2415
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Possibly fakes. They should all fall in the BL IDSS range, else very suspect parts.
Old 10th February 2012, 11:42 AM   #2416
To others. Just beware - these came from www.dalbani.co.uk .
I will be phoning them shortly to see what they propose to do about the fakes.
Old 10th February 2012, 11:46 AM   #2417
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Neve done business with them but dabani supposedly has a good reputation, but those do sound fake. I have a 100 coming from a certified source. I will send you some at cost if you are willing to wait and pay shipping to the UK.
Old 10th February 2012, 11:56 AM   #2418
Buzzfoorb.
I'll take you up on that offer please.
Old 10th February 2012, 11:57 AM   #2419
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I bought a batch of 100 from spencer and they ranged from about 6.5 t0 11. 2.2 is definitely very suspect.
Andrew, when did you start using 1R0? Isn't that a tad low? I used a 0.1% 100 ohm resistor and that seems to work quite nicely. Perhaps 100 ohms doesn't give quite enough resolution though for really close matching, a 10 ohm resistor would allow me to use the 200mV range on the multimeter rather than the 2V range... I assume this is the reason for going with such a low resistor value? Or is it because you can just use the reading without needing to divide by the resistance?
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 10th February 2012 at 11:58 AM. Reason: removed dumb comment ;)
Old 10th February 2012, 12:00 PM   #2420
buzzforb's Avatar
Originally Posted by KatieandDad View Post
Buzzfoorb.
I'll let you know when I get them.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
