Building a symmetrical psu B1 buffer
Old 7th February 2012, 03:43 PM   #2401
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by buzzforb View Post
Any benefir to using v rated parts in dcb1?
No, they may even cause self heating problems.
Originally Posted by KatieandDad View Post
I've heard of V rated tyres for cars but never V rated components ???
He just means Violet grade (highest IDSS group in Toshiba's literature, BL is BLue) I suppose.
Old 7th February 2012, 03:57 PM   #2402
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by Salas View Post
Not far.
Sorry but "Not Far", what do you mean ?
Old 7th February 2012, 03:58 PM   #2403
I can certainly measure them again with the 2SK170BL as a CCS.
The minor differences between different 2SK170s must surely be similar to the circuit that I used.
Obviously the ULTIMATE measurement must be with the particular 2SK170 that you are using with each LED string.
I suppose this is what makes this amplifier impossible to produce commercially.
Old 7th February 2012, 04:08 PM   #2404
Salas's Avatar
I mean its not far from real conditions. Best accuracy for finding their Vf in circuit would be to use their real K170 destined to power them in the build of course. To produce such a buffer in the way some meticulous members put it together in this thread, forget it cost wise indeed.
Old 7th February 2012, 04:29 PM   #2405
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Wouldnt it just amount to lower output impedance. Beimg 100% feedback already, you wouldnt get better distortion numbers, correct.
Old 7th February 2012, 04:57 PM   #2406
Salas's Avatar
Problem is their self dissipation. Would need some special TO-92 double sink to help them and lock their drift by coupling their temp in pairs. Buffer's Zo is limited by the necessary output series resistor anyway, but the more conductance the less THD of course. Also the more Ciss unfortunately, maybe 10K pot max if like that with K170V in the audio part. Not good in the PSU part due to capacitance and drift.
Old 7th February 2012, 05:07 PM   #2407
buzzforb's Avatar
Cool! Thanks.
Old 8th February 2012, 07:04 AM   #2408
R.I.P.
Speaker manufacturers have been selecting measured components for decades.
Every driver gets measured. Every critical crossover component gets measured. The computer then "cherry picks" the combination of drivers and components to get the final speaker within that model's tolerance range.
This could easily be applied to a simple amplifier.
But is there a market for tens of thousands that the computer could send out?
regards Andrew T.
Old 9th February 2012, 03:02 PM   #2409
SALAS could you possibly PM me the Silk Screen for the attached board so that I can transfer it onto my HomeBrew board.
Many Thanks
Andy
Old 9th February 2012, 04:15 PM   #2410
I'm just waiting for the PSU caps and a back order of 2SK170BLs before I start building.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
