Old 5th February 2012, 02:05 PM   #2391
KatieandDad's Avatar
The only problem that I am having with the Toner Transfer method is that I have whiskers between tracks that I have to get rid of.
The photo etch process, IMHO, is far more accurate.
Old 5th February 2012, 02:26 PM   #2392
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by KatieandDad View Post
Looking at POST 138 you are using traffic lights to acurately produce the reference voltages - Am I right in this assumption ?
You mean the pictures of the black original boards in post 138 I guess. Yes some combine colors. Try 9.4V total, the old ones had an additional drop of a 10R that boosted the 9V a bit. No sinks low Id build that one. Easy to squeeze in crowded box.
Old 5th February 2012, 02:47 PM   #2393
Salas's Avatar
I've been busy measuring my collection of LEDs - well the 3mm RED and GREEN ones.
I reckon that the best match that I can get for 9V and 5V4 is as follows.
9V = RED RED RED GREEN GREEN. (1.61+1.62+1.61+2.08+2.08 = 9V0)
5V4 = RED RED GREEN. (1.63+1.63+2.11 = 5V37)
I can then match both strings to within 10mV of each other and the target voltage.
Is that sufficiently accurate ?
How did you measure those? This is the best method to measure near real circuit operating conditions:
Old 6th February 2012, 07:11 PM   #2394
tommy_o is offline tommy_o  United States
Hey there, I am just starting to source components and wanted to double check the transformer selection before proceeding. Is an Antek AN-0515 appropriate? Specs read 15V and 50VA, but I can't tell if it is 15+0+15 or not (or if I should be using a different product altogether). Link is here .
Or does anyone know of a more logical transformer choice (lower the price, the better; for someone in USA).
Old 6th February 2012, 07:14 PM   #2395
Marra is offline Marra  United Kingdom
The link says two outputs so it should be 0-15;0-15. You would just need to common the two centre wires to make 15-0-15 to connect to the pcb. 50VA is fine if you want to go down the hotrod line.
Old 6th February 2012, 07:15 PM   #2396
Great, thanks Marra!
Old 7th February 2012, 02:16 PM   #2397
I used a 5V regulated supply and a series 330R resistor to simulate a 10mA current.
I thought that would be accurate enough.
I've just sourced a pair of 0-15 0-15 50VA toroids. I only need one so I've put the other on Swap-Meet.
Old 7th February 2012, 03:20 PM   #2398
buzzforb's Avatar
Any benefir to using v rated parts in dcb1?
Old 7th February 2012, 03:27 PM   #2399
I've heard of V rated tyres for cars but never V rated components ???
Old 7th February 2012, 03:41 PM   #2400
Salas's Avatar
Not far.
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2013 diyAudio
