Building a symmetrical psu B1 buffer
Old 27th December 2011, 11:05 AM   #2301
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Hi Andrew,
what do you mean "errors" ?
Is there anything wrong with the Mezmerize boards ?
I've got one nearly stuffed....?(
preregulatorpeterE-MAIL
Old 27th December 2011, 11:07 AM   #2302
Some of the designers choices were discussed early in the DCB1 Thread.
The designer was not interested in feedback.
Those choices ended up in the traces.
I told you all, but you refused to listen.
regards Andrew T.
Old 27th December 2011, 11:15 AM   #2303
Benedetto's Avatar
Sorry Andrew,
just because i'd bought it long time ago i thought
everything is ok.
My fault, did'nt read the thread properly.
Old 27th December 2011, 11:45 AM   #2304
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The boards are fine, this is a project repeated successfully in the hundreds already. Don't worry.
P.S.
Andrew, if you will repeat claims that the boards are in error, I will have to report your posts.
Old 27th December 2011, 11:50 AM   #2305
Report my warnings.
I have the evidence to show the "errors". These can be found in the Thread.
I also have the evidence to show how to correct many of the errors.
regards Andrew T.
Old 27th December 2011, 12:01 PM   #2306
Salas's Avatar
The boards are following the design correctly. There are no discrepancies or faults in this regard. Ideas about what you may like to do differently are not accountable as fixing errors in the boards. This is a well seasoned and tried out project with tons of ''all well'' feedback. If you don't like it, post your own, make a thread. Enough is enough.
Old 27th December 2011, 01:32 PM   #2307
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by AndrewT View Post
In the meantime I am developing Mezmerize into a multi-input pre-amp. There are many traces that need to be re-routed to remove errors in the standard PCB. I think I am almost there.
Any chance to show us your progress?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 27th December 2011, 02:30 PM   #2308
Salas's Avatar
Any modification to the boards of any system that is referred as ''DCB1'', ''Mezmerize'', ''Hypnotize'', carries the name ''Salas'', or makes use of shunt regulators same as those incorporated to the above listed, is unofficial, not endorsed, not recommended, and not allowed to use those titles and PSUs. Any new idea, modification, spin off, or PCB resembling those, should be presented and discussed in another thread and be an entirely different project not carrying any reference to my name.
Old 27th December 2011, 02:44 PM   #2309
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Salas, does the dcb1 stand to benefit sonically from a constant impedance volume control source over the typical pot which of course changes impedance according to attenuation.
Old 27th December 2011, 02:50 PM   #2310
Salas's Avatar
If you had the opportunity to use a volume control source with steady output impedance in the recommended 10-20kOhm range, the bandwidth would be steady too. That is due to keeping a steady relation with the Jfet input capacitance. If that could be a subjective improvement I am not in a position to tell since I haven't used anything like that.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 02:14 AM
