Old 17th April 2011, 11:42 AM   #2201
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by william2001 View Post
I would guess this switch is the one you want: SPST Round Rocker Switch w/Red Illumination 125VAC
I like the large DPDT switches myself (I use the 060-310). Bit of a pain to cut the hole though. The fuses you found should be OK.
Yep,
I dont care for illuminated switches myself.
But 12v switches are often for automotive work I guess.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 17th April 2011, 01:22 PM   #2202
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
DPDT Rocker Switch
hinted to by William...I find only one switch from that source that I would use.
DPDT will disconnect both legs of a circuit when not in use.
Rated 250VAC
Old 17th April 2011, 01:32 PM   #2203
Originally Posted by Ed LaFontaine View Post
DPDT Rocker Switch
Rated 250VAC
How to connect or wire the DPDT with the transformer? When I built the ClassDAudio amplifier, it puts a SPST switch in series with the AC-L.
Thx!
Old 17th April 2011, 01:36 PM   #2204
Paro,
you should not allow yourself to wire up any mains powered project without trained supervision looking over your shoulder !!!!!
Old 17th April 2011, 02:08 PM   #2205
william2001's Avatar
Check out this page for some direction on mains wiring. You certainly need to understand exactly what you are doing with this part of diy. The fun can come to a screeching halt real quick if you don't. And please be sure to use heatshrink tubing on all of the exposed terminals and connections.
Power Supply Wiring Guidelines
Old 17th April 2011, 02:15 PM   #2206
Marra is offline Marra  United Kingdom
These are good assuming you can reach round the back of your DCB1 to turn on and off.
MULTICOMP|JR-101-1-FRSG-02|INLET, IEC, DPST, WITH FUSE HOLDER | Farnell United Kingdom
Old 17th April 2011, 02:35 PM   #2207
Thanks! I have a good direction now.
Old 17th April 2011, 03:45 PM   #2208
Originally Posted by CanAm Man View Post
I....guess....this could even be considered an alternative for a 12V power switch.
Old 17th April 2011, 03:45 PM   #2209
I....guess....this could even be considered an alternative for your power switch.
(Be careful. Wiring "mains" circuits can be deadly. Have an experieced friend assist you--and have them double-check your work)
Old 17th April 2011, 03:47 PM   #2210
How can my reply including a quote from a post appear before that quoted post?
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
Copyright ©1999-2013 diyAudio
