Old 2nd October 2010, 09:38 AM   #2071
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
To clarify the graph: The 100k was to simulate F5's published 100K Zin. Practically it would be DCB1, 1uF cap, 1Meg or more to ground, RCA, F5. 91K total if with 1Meg after cap to ground.
Old 2nd October 2010, 11:50 AM   #2072
Tripmaster's Avatar
Hi
I have 3.3 or 4.7uf caps to hand if you feel either of these will measure better. I'm happy to purchase a different value if required.
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 2nd October 2010, 11:55 AM   #2073
perfect!
Build up the source with the 1uF temporary tacked on.
Listen and evaluate.
ADD the 3u3F, also tacked on.
Was there any difference in the sound before and after?
Choose which you prefer and solder in permanently.
Old 2nd October 2010, 12:03 PM   #2074
Tripmaster's Avatar
Originally Posted by AndrewT View Post
perfect!
Will do. Good idea
Richard
Old 2nd October 2010, 12:33 PM   #2075
Not to get off topic, but doesnt too big of a input cap start affecting the highs?
Old 2nd October 2010, 12:41 PM   #2076
then try mix and match if you believe this is an issue.
I believe it is far more important that the input filtering is of narrower bandwidth than the amplifier/pre-amplifier can reproduce well.
eg. setting the amplifier input filtering to F-3dB @ 3Hz and 200kHz, requires the amplifier to work well over the bandwidth of 1.5Hz to 400kHz.
Old 2nd October 2010, 02:14 PM   #2077
Guitar Pedals: R-C Filter Calculator
You figure you want your -3db to be 2 octaves out from what your system can reproduce to get rid of phase problems.
Hes got 100k in:
for full range (odds are highly unlikey either his music or his speakers can produce)20-20k
input cap would be 0.318uf for 5 hz
my simple calc wont do ultra sonic calcs.
Old 2nd October 2010, 07:54 PM   #2078
Tripmaster's Avatar
Hi
I have just finished wiring my L/S attenuator into the DCB1 and I appear to have some DC on right output channel, left appears fine.
When I turn on the attenuator and DCB1 at the same time the right channel peaks at ~1.4v before the relay clicks in, and then drops to 0v after the 5 second click. When I turn it off the right output peaks at ~800mV and very slowly decreases. As I am only in the checking phase I haven't connected it to my amp...thankfully
Any ideas?
Richard
Old 2nd October 2010, 07:57 PM   #2079
Salas's Avatar
What happens if you are turning them on in separate times?
Old 2nd October 2010, 08:22 PM   #2080
Tripmaster's Avatar
Hi Salas
It happens if I turn on the DBC1 first, the L/S doesn't make any difference.
Richard
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
