Building a symmetrical psu B1 buffer
Old 1st October 2010, 11:08 AM   #2061
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
OK then, clarified. Enjoy it.
Old 1st October 2010, 04:25 PM   #2062
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Hi
I've finished stuffing the board and everything appears to be OK.
I am getting +10.17v and -9.52v at the shunt output, and the DC offset is R=0.1mV and L=0.2mV when idling. It does occasionally rise a bit when turning on or off, but I understand this is to be expected. The relay also clicks-in after a few seconds. I will be using this with my F5 so I'll be adding a 1uf cap on the amps input.
Is there anything else I should check before connecting my LDR attenuator?
Old 1st October 2010, 04:53 PM   #2063
R.I.P.
check the voltage drops across the CCS resistors.
check the output offset from OFF to ON and from cold to operating temp.
The relay should be open when the circuit starts up and open again when the circuit shuts down. You should not see a DC pulse at startup nor at switch off.
1uF for a DC blocking cap seems quite low in value for the input of a Power Amp.
Are you intending to EQ the bass for a particular sound effect?
regards Andrew T.
Old 1st October 2010, 05:38 PM   #2064
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Wouldn't that just depends on the input impedance resistor to ground? An RC filter will be affected by both the resistance and the capacitance...
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 1st October 2010, 07:58 PM   #2065
Tripmaster's Avatar
Hi
I thought 1uf was the correct value for an F5. I'm sure I have seen it mentioned elsewhere. But if I'm wrong...
All of the LEDs measured 1.8v when testing prior to soldering, the relay clicks after 5 seconds after turn on, and clicks again straight after switch off.
I measured the voltage across the 2x68R (34R) resistors. Negative side 1.76v and positive side 1.64v
I've just rechecked the dc offset whilst 'cold' and there doesn't appear to be any, just a slight bit of interference from the DMM. I will check the 'hot' readings a little later.
Old 1st October 2010, 09:04 PM   #2066
Marra is offline Marra  United Kingdom
2.2uF would work even down to a 20k Zin amp.
Recommended by Salas in the Blue Hypno thread ; post 217 and working well with my DCB1 and Aleph 5.
Marra
Old 1st October 2010, 09:51 PM   #2067
Salas's Avatar
Looks like working perfectly OK Richard. Congratulations. In the graph is the high pass you can expect when coupling 1uF to 100K load.
Old 1st October 2010, 10:26 PM   #2068
Tripmaster's Avatar
Thanks Salas. That graph looks good?
Old 1st October 2010, 10:34 PM   #2069
Salas's Avatar
If your speakers can go lower than 1.8Hz -3dB then its not enough.
Seriously, you may use more uF for even less infrasonic phase shift but for sheer amplitude you are way well covered for 100K input F5 as you see in the graph.
Old 2nd October 2010, 09:05 AM   #2070
R.I.P.
Have a proper look.
That graph of low frequency response is for 1uF & 100k.
The output of your circuit is already loaded with 100k.
To achieve that graphed response the following Power Amp or receiver needs to have Zin = infinity.
If the actual Zin = 100k, then the resultant load for the HP filter is 50k. This moves the graph one octave to the right.
The F5 has no DC blocking cap at it's input so the 1uF works alone.
The Zin ~ 101k.
This leaves the HP filter F-1dB ~3Hz.
This is OK for many.
If as stated earlier, a Zin=20k were used then F-1dB moves to ~17Hz.
If that Zin=20k power amp had a capacitor of 4u7F as a DC blocker then F-1dB moves to ~22Hz
Summarising:
1uF at the source output only suits very high Zin at the receiver that is DC coupled.
regards Andrew T.
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
