Building a symmetrical psu B1 buffer
Old 6th October 2009, 08:39 PM   #191
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What is it for? You will run 200mA CCS with those 16R in parallel. Sink accordingly. +/- 15V smells like op amps?
Old 6th October 2009, 08:54 PM   #192
npapp is offline npapp  United States
Yes Opamps, I/V stage from Buffalo24. current requirement 60-70ma. I have been listening to this DAC as is for several months now so hopefully I will be able hear any difference with the new psu.
Old 6th October 2009, 09:16 PM   #193
udailey is offline udailey  United States
Passive Aggressive
7812 in place and there is still no relay clicking. LED still not turning on near 7812. After several seconds I start to hear this weird sound. Real low volume and it sounds like if you put your ear in a Conch shell. I dont think this is the sound I was looking for LOL
.5A fuse blew. I replaced it and it is not blowing again. However I got one of those Antek 50VA 15V toroids and wired it up, then turned it on and started hearing that sound for the first time. So I removed it and put back the CT transformer. Sound is still there.
Still worries me. Rails are different now. 10.2 and 11. R1 has 2.16 and 2.04.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 6th October 2009, 09:22 PM   #194
Salas's Avatar
Where do you hear that sound? Near the relay? Comes from it?
Old 6th October 2009, 09:22 PM   #195
Passive Aggressive
Is this that oscillation that everyone has mentioned?
Old 6th October 2009, 09:23 PM   #196
Passive Aggressive
sorry posted at same time, I didnt want to stick my head to close to it. I will now enter the mouth of the beast.
Uriah
Old 6th October 2009, 09:25 PM   #197
Passive Aggressive
Its hard to tell. I think I will go pick up my wife from work and then after dinner add that cap and see if I get rid of the noise.
Uriah
Old 6th October 2009, 09:26 PM   #198
Salas's Avatar
Kannan had a ''chatter'' and Tea bag. Kannan changed a 7812 and was gone. If it is that, put a 0.15u cap across C,B of the transistor that drives the relay (the one facing towards the 2 drop resistors). But first, tell me, what voltage you measure from those 2 resistors output to ground?
Old 6th October 2009, 09:43 PM   #199
kannan_s is offline kannan_s  United States
Send a message via Yahoo to kannan_s
Uriah
When you power up - you will not hear the noise till few seconds later - you can hear the click of the realy coils and then you will hear the noise. If that is the case, then the noise is from the relay due to some sort of voltage spikes on relay coils. You can solder 150nF cap - across the transistor driving between C/B - you can read the thread - you can eevn see Salas' post with clear location of this cap. This should cure the chatter issue. Any value 0.1nF to .22NF cap will do.
kannan
Old 6th October 2009, 09:44 PM   #200
billyk is offline billyk  United States
billyk's Avatar
Uriah
Old car repair trick I used to use listening to the inside of an engine. I would place a long screwdriver on that part of the motor and my ear against the other end. The sound would then be transmitted to my ear. If you have something like a dowel rod, maybe a wooden ruler, you could place it on the relay and hear if it was from there??
Building a symmetrical psu B1 bufferHide this!Advertise here!
New-building of my B1 buffer Babowana Pass Labs 328 20th February 2010 01:14 AM
